最近正在玩2410的arm9
移植了nand闪存的uboot后,载入开发板带的linux内核,启动不了
下面是启动信息,难道不能在SDRAM中跑吗?
顺便问下uboot怎么对nand分区呢?
先载入了镜像
YANGCHU2410 # tftp 31000000 uImage
TFTP from server 192.168.0.54; our IP address is 192.168.0.53
Filename 'uImage'.
Load address: 0x31000000
Loading: #################################################################
done
Bytes transferred = 772336 (bc8f0 hex)
用bootm运行不能
YANGCHU2410 # bootm 31000000
## Booting image at 31000000 ...
Image Name: linux-2.4
Created: 2008-07-27 2:53:18 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 772272 Bytes = 754.2 kB
Load Address: 30008000
Entry Point: 30008000
Verifying Checksum ... OK
OK
Starting kernel ...
arch_number:c1
boot_params:30000100
Uncompressing Linux....................................................... done, booting the kernel.
Linux version 2.4.18-rmk7-pxa1 (fc@localhost.localdomain) (gcc version 2.95.3 20010315 (release)) #441 二 7月 10 11:29:04 CST 2007
CPU: ARM/CIRRUS Arm920Tsid(wb) revision 0
Machine: Samsung-SMDK2410
On node 0 totalpages: 16384
zone(0): 16384 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: /dev/ram
DEBUG: timer count 15626
Console: colour dummy device 80x30
Calibrating delay loop... 49.86 BogoMIPS
Memory: 64MB = 64MB total
Memory: 62596KB available (1372K code, 356K data, 140K init)
Dentry-cache hash table entries: 8192 (order: 4, 65536 bytes)
Inode-cache hash table entries: 4096 (order: 3, 32768 bytes)
Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
Buffer-cache hash table entries: 4096 (order: 2, 16384 bytes)
Page-cache hash table entries: 16384 (order: 4, 65536 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
CPU clock = 200.000 Mhz, HCLK = 100.000 Mhz, PCLK = 50.000 Mhz
Initializing S3C2410 buffer pool for DMA workaround
check your kernel config.
Starting kswapd
devfs: v1.10 (20020120) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
ttyS%d0 at I/O 0x50000000 (irq = 52) is a S3C2410
ttyS%d1 at I/O 0x50004000 (irq = 55) is a S3C2410
ttyS%d2 at I/O 0x50008000 (irq = 58) is a S3C2410
Console: switching to colour frame buffer device 80x30
Installed S3C2410 frame buffer for TFT 640x480 LCD.
pty: 256 Unix98 ptys configured
S3C2410 Real Time Clock Driver v0.1
block: 128 slots per queue, batch=32
eth0: cs8900 rev K(3.3 Volts) found at 0xd0000300
cs89x0 media RJ-45, IRQ 37
loop: loaded (max 8 devices)
Linux video capture interface: v1.00
SCSI subsystem driver Revision: 1.00
UDA1341 audio driver initialized
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V)
NAND_ECC_NONE selected by board driver. This is not recommended !!
Creating 3 MTD partitions on "NAND 64MiB 3,3V":
0x00000000-0x00020000 : "boot"
0x00040000-0x00200000 : "kernel"
0x00200000-0x03ef8000 : "rootfs"
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-ohci.c: USB OHCI at membase 0xe9000000, IRQ 26
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 2 ports detected
usb.c: registered new driver hid
hid-core.c: v1.8 Andreas Gal, Vojtech Pavlik <vojtech@suse.cz>
hid-core.c: USB HID support drivers
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 4096 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Fast Floating Point Emulator V0.9 (c) Peter Teichmann.
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "" or 02:00
Please append a correct "root=" boot option
Kernel panic: VFS: Unable to mount root fs on 02:00 |
