发表于 2008-9-14 00:24:39
** daxinganling@hotmail.com
** Filename : Receive And Send Uart6 in interrupt mode
** Abstract : This file implements main function.
** APIlib : NEC78K0SKX1+.lib V1.70 [7 Dec. 2006]
** Device : uPD78F9234
** Compiler : NEC/CC78K0
#pragma interrupt INTSR6 MD_INTSR6
#pragma interrupt INTST6 MD_INTST6
#include "macrodriver.h"
#include "system.h"
** MacroDefine
** Abstract:
** This function implements main function.
** Parameters:
** None
** Returns:
** None
extern void hdwinit(void);
bit rx_flag;
bit sd_flag;
unsigned char TEMP;
void UART6_Init( void )
ASIM6 = 1; /* ENABLE INTERNAL CLOCK OPERATION*/
SetIORBit(P4, 0x08); /* port setting in transmit/receive mode */
ClrIORBit(PM4, 0x08);
SetIORBit(PM4, 0x10);
SetIORBit(ASIM6, 0x04); /* data length 8 bits */
SetIORBit(ASIM6, 0x10); /* odd bits */
ClrIORBit(ASIM6, 0x02); /* stop length 1 bit */
SetIORBit(ASICL6, 0x02); /* LSB-first transfer */
CKSR6 = 0x1; /* baudrate selection 9600*/
BRGC6 = 0xd0;
ClrIORBit(IF1, 0x60);
ClrIORBit(MK1, 0x60); /* UART6 transmit/receive end interrupt enable */
SetIORBit(ASIM6, 0x80);
SetIORBit(ASIM6, 0x60); /* UART6 transmit/receive mode */
bit SENDCHAR(UCHAR TEMP)
sd_flag = 0;
TXB6 = TEMP;
while(!sd_flag);
return 1;
bit SENDSTRING(UCHAR *databuf, UCHAR txnum,UCHAR format)
UCHAR i = 0;
for(i=0;i<txnum;i++)
TEMP = *(databuf+i);
SENDCHAR(TEMP);
if(format)
TEMP ='\n';
SENDCHAR(TEMP);
return 1;
__interrupt void MD_INTST6( void )
sd_flag = 1;
__interrupt void MD_INTSR6( void )
rx_flag = 1;
void delay(int ms)
while(ms--);
void main( void )
hdwinit();
UART6_Init();
SENDSTRING("HELLO BOY",9,1);
while(rx_flag)//表示有数据收到标志
rx_flag = 0;
SENDSTRING("RECEIVE DATA:",13,0);
SENDCHAR(RXB6);//发送收到的数据
SENDCHAR('\n');
