用这个做雕刻机主轴可以吗?有没有人出来说说优缺点。
PORTER*CABLE 890
120V 12A 10000-23000/mim
2-1/4 HP (Maximum Motor HP) Fixed Base Router Kit890
The 890 includes Includes router motor, Fixed Base, 1/4" & 1/2" collets, Collet wrench, Carrying case, Operating manual.
Soft-starting, 12 Amp motor featuring full-time electronic feedback that maintains motor speed through the toughest applications Variable-speed control feature (10,000 - 23,000 rpm) enables bit speed to be optimized for changing applications
Release the motor, adjust bit height, and clamp the motor from above the router table with 3/16" hex socket (sold separately) or model #75301 kit (sold separately)
Dual-position switch allows user to cut power while maintaining control of the router
Overmolded rubber handles provide a comfortable and secure grip
Spindle lock system disables switch when engaged for router bit changes
Durable latch lever enables quick and simple coarse depth adjustments and motor release for transition between bases
Rack and pinion adjustment provides fine depth settings to 1/128"
Collets included to accept 1/4" and 1/2" shank bits
Motor transitions quickly between fixed base (included), plunge base (8931), and traditional spiral down bases (690 series)
(原文件名:用这个做雕刻机主轴可以吗?.jpg)
本贴被 jjj206 编辑过,最后修改时间:2008-09-16,12:11:13. |
