发表于 2008-9-18 21:08:12
多谢! 顺便贴下刚搜到的 可以用
我用Delphi7試過用SelectDirectory,在Delphi7中的SelectDirectory是可以有預設的,所以我將Delphi7的SelectDirectory的原代碼改在Delphi5內測試,改了函數的名稱叫SelectFolder,經過我改動後,新的SelectFolder函數是可以做到我預期的效果了,以下是我的編碼
unit Unit1;
interface
uses
Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs,
filectrl, StdCtrls;
type
TForm1 = class(TForm)
Button1: TButton;
procedure Button1Click(Sender: TObject);
end;
var
Form1: TForm1;
implementation
uses
ShlObj, ActiveX;
{$R *.DFM}
function SelectDirCB(Wnd: HWND; uMsg: UINT; lParam, lpData: LPARAM): Integer stdcall;
begin
if (uMsg = BFFM_INITIALIZED) and (lpData <> 0) then
SendMessage(Wnd, BFFM_SETSELECTION, Integer(True), lpdata);
result := 0;
end;
function SelectFolder(const Caption: string; const Root: WideString;
var Directory: string): boolean;
var
WindowList: Pointer;
BrowseInfo: TBrowseInfo;
Buffer: PChar;
OldErrorMode: Cardinal;
RootItemIDList, ItemIDList: PItemIDList;
ShellMalloc: IMalloc;
IDesktopFolder: IShellFolder;
Eaten, Flags: LongWord;
begin
Result := False;
if not DirectoryExists(Directory) then
Directory := '';
FillChar(BrowseInfo, SizeOf(BrowseInfo), 0);
if (ShGetMalloc(ShellMalloc) = S_OK) and (ShellMalloc <> nil) then
begin
Buffer := ShellMalloc.Alloc(MAX_PATH);
try
RootItemIDList := nil;
if Root <> '' then
begin
SHGetDesktopFolder(IDesktopFolder);
IDesktopFolder.ParseDisplayName(Application.Handle, nil,
POleStr(Root), Eaten, RootItemIDList, Flags);
end;
with BrowseInfo do
begin
hwndOwner := Application.Handle;
pidlRoot := RootItemIDList;
pszDisplayName := Buffer;
lpszTitle := PChar(Caption);
ulFlags := BIF_RETURNONLYFSDIRS;
if Directory <> '' then
begin
lpfn := SelectDirCB;
lParam := Integer(PChar(Directory));
end;
end;
WindowList := DisableTaskWindows(0);
OldErrorMode := SetErrorMode(SEM_FAILCRITICALERRORS);
try
ItemIDList := ShBrowseForFolder(BrowseInfo);
finally
SetErrorMode(OldErrorMode);
EnableTaskWindows(WindowList);
end;
Result := ItemIDList <> nil;
if Result then
begin
ShGetPathFromIDList(ItemIDList, Buffer);
ShellMalloc.Free(ItemIDList);
Directory := Buffer;
end;
finally
ShellMalloc.Free(Buffer);
end;
end;
end;
procedure TForm1.Button1Click(Sender: TObject);
var
ss: string;
begin
ss := 'D:\BURN';
if SelectFolder('Choose Folder','',ss) then
showmessage('Your Choose is ' + ss);
end;
end.
Anyway, 多謝各位的幫忙 |
