回复: 57
我自己做的会唱歌的STM32实验板【恢复】
发表于 2008-10-9 09:21:22 | 显示全部楼层 |阅读模式
以下文字由站长阿莫加入:
4,6,11楼能分别下载到电路图,说明书,测试代码。
这是我做的STM32实验板
 (原文件名:IMG_5805.JPG)
通过改变PWM的频率可以发出不同的音调,从而唱出简单的歌曲
下面是主要的程序,唱的是SuperStar
#include "Include.h"
//音调表
//C 262
//D 294
//E 330
//F 349
//G 392
//A 440
//B 494
//C 523
//D 587
//E 659
//F 698
//G 784
//A 880
//B 988
//C 1047
//D 1175
//E 1319
//F 1397
//G 1568
//A 1760
//B 1976
//低音1~7
const unsigned int MusicDataD[7] = {61069,54422,48485,45845,40816,36364,32389};
//中音1~7
const unsigned int MusicData[7] = {30592,27257,24297,22922,20408,18182,16194};
//高音1~7
const unsigned int MusicDataG[7] = {15282,13617,12130,11453,10204,9091,8097};
//音乐数据格式:
//0x11~0x17 表示低音1~7
//0x21~0x27 表示中音1~7
//0x31~0x37 表示高音1~7
//0         表示静音
//每个音后面数据表示该音为多少个时间单位:1个16分音符定为1个时间单位
const unsigned char SuperStarData[] = //SuperStar S.H.E.
        0x22,4,0x22,2,0x23,2,0x21,4,0x15,2,0x15,2,
        0x22,2,0x21,2,0x22,2,0x23,2,0x21,4,0,2,0x23,2,
        0x24,2,0x23,2,0x21,2,0x21,1,0x22,1,0x22,4,0,2,0x23,2,
        0x24,2,0x23,2,0x21,2,0x21,2,0x21,2,0x22,1,0x21,1,0x17,4,
        0x22,2,0x22,2,0x22,2,0x23,2,0x21,4,0x15,2,0x15,2,
        0x24,2,0x23,2,0x24,2,0x25,2,0x25,4,0x15,2,0x16,2,
        0x21,4,0x22,2,0x23,2,0x25,4,0x23,2,0x25,2,
        0x26,2,0x27,2,0x26,2,0x25,2,0x23,4,0x22,2,0x23,2,
        0x25,2,0x23,2,0,2,0x23,2,0x22,2,0x23,2,0x22,2,0x21,2,
        0x15,8,0,4,0x15,2,0x16,2,
        //1
        0x15,16,
        0,32,
        //2
        0x15,16,
        0,4,0x26,2,0x25,6,0x22,2,0x23,10,0,8,
        0,4,0x26,2,0x25,6,0x22,2,0x23,4,0x24,2,0x23,1,0x22,1,0x21,1,0x21,9,
        0,4,0x26,2,0x25,6,0x27,2,0x27,6,0,2,0x27,2,0x31,4,0x27,2,0x26,2,
        0x26,4,0x22,2,0x23,2,0x21,4,0x15,2,0x15,2,
        0x24,2,0x23,2,0x21,2,0x22,2,0x22,4,0,2,0x23,2,
        0x24,2,0x23,2,0x24,2,0x25,2,0x25,20,0x15,2,0x16,2,
        0x15,12,0,4,
void SetBellF(unsigned int SetV)
        TIM_OCInitTypeDef TIM_OCInitStructure;
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        TIM_TimeBaseInitStructure.TIM_Period = SetV;
        TIM_TimeBaseInitStructure.TIM_Prescaler = 0;
        TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = (SetV/2);
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
        TIM_OC2Init(TIM2, &TIM_OCInitStructure);
void Timer2Init(void)
        TIM_TimeBaseInitStructure.TIM_Period = 10000;
        TIM_OCInitStructure.TIM_Pulse = 5000;
void Timer2OutEnable(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
void Timer2OutDisable(void)
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
void Timer2Start(void)
        TIM_Cmd(TIM2, ENABLE);
void Timer2Stop(void)
        TIM_Cmd(TIM2, DISABLE);
//播放歌曲
void PlayMusicFile(unsigned int DataNumber,unsigned char* p,unsigned char UnitTime)
        unsigned int i = 0;
        unsigned int PlayWord;
        for(i=0;i<DataNumber;i++)
                switch (*p)
                        case 0x11:
                                PlayWord = MusicDataD[0];
                        case 0x12:
                                PlayWord = MusicDataD[1];
                        case 0x13:
                                PlayWord = MusicDataD[2];
                        case 0x14:
                                PlayWord = MusicDataD[3];
                        case 0x15:
                                PlayWord = MusicDataD[4];
                        case 0x16:
                                PlayWord = MusicDataD[5];
                        case 0x17:
                                PlayWord = MusicDataD[6];
                        case 0x21:
                                PlayWord = MusicData[0];
                        case 0x22:
                                PlayWord = MusicData[1];
                        case 0x23:
                                PlayWord = MusicData[2];
                        case 0x24:
                                PlayWord = MusicData[3];
                        case 0x25:
                                PlayWord = MusicData[4];
                        case 0x26:
                                PlayWord = MusicData[5];
                        case 0x27:
                                PlayWord = MusicData[6];
                        case 0x31:
                                PlayWord = MusicDataG[0];
                        case 0x32:
                                PlayWord = MusicDataG[1];
                        case 0x33:
                                PlayWord = MusicDataG[2];
                        case 0x34:
                                PlayWord = MusicDataG[3];
                        case 0x35:
                                PlayWord = MusicDataG[4];
                        case 0x36:
                                PlayWord = MusicDataG[5];
                        case 0x37:
                                PlayWord = MusicDataG[6];
                        default:
                                PlayWord = 0;//表示无声音
                p++;
                i++;
                if(PlayWord != 0)
                        Timer2OutEnable();
                        SetBellF(PlayWord);
                        Timer2OutDisable();
                DelayNmS(UnitTime*(*p));
                p++;
void Timer2Test(void)
        unsigned char i = 0;
        Timer2Start();
                while(NO_KEY == GetKey());
                PlayMusicFile(sizeof(SuperStarData),(unsigned char*)SuperStarData,100);
                Timer2OutDisable();
        //一句简单的歌曲
        while(0)
                Timer2OutEnable();
                SetBellF(MusicData[0]);
                DelayNmS(400);
                DelayNmS(400);
                SetBellF(MusicData[4]);
                DelayNmS(400);
                DelayNmS(400);
                SetBellF(MusicData[5]);
                DelayNmS(400);
                DelayNmS(400);
                DelayNmS(400);
                DelayNmS(400);
                SetBellF(MusicData[3]);
                DelayNmS(400);
                DelayNmS(400);
                SetBellF(MusicData[2]);
                DelayNmS(400);
                DelayNmS(400);
                SetBellF(MusicData[1]);
                DelayNmS(400);
                DelayNmS(400);
                DelayNmS(400);
                DelayNmS(400);
                Timer2OutDisable();
                DelayNmS(1000);
        //从C播放到B
                SetBellF(MusicData);
                Timer2OutEnable();
                DelayNmS(200);
                i++;
                if(i>=7)
                        i = 0;
                        Timer2OutDisable();
                        DelayNmS(2000);
void TestPlay(void)
        Timer2Start();
发表于 2008-10-9 09:26:25 | 显示全部楼层
赞一个~
发表于 2008-10-9 10:36:59 | 显示全部楼层
记号。
发表于 2008-10-9 11:23:20 | 显示全部楼层
楼主上原理图、pcb图。
好像没有外扩的I/O!不解.................
想是楼主把STM32当51了!
 楼主| 发表于 2008-10-9 12:37:24 | 显示全部楼层
为什么一定要外扩IO呢?
我选用的是STM32F103C6T6,就48脚,没打算外扩。
附上原理图:
点击此处下载 ourdev_445070.pdf(文件大小:21K) (原文件名:EasySTM32V1.1.pdf)
 楼主| 发表于 2008-10-10 18:01:15 | 显示全部楼层
我把板子放淘宝上了,大家有兴趣可以去看看哦
http://auction1.taobao.com/auction/item_detail-0db1-b8d83af207f1916f6d6bfc886bd9f586.jhtml
 楼主| 发表于 2008-10-10 21:13:13 | 显示全部楼层
说明书也上传过来请大家都看看
点击此处下载 ourdev_446790.pdf(文件大小:460K) (原文件名:EasySTM32说明书.pdf)
发表于 2008-10-10 22:13:51 | 显示全部楼层
不错的广告!
头像被屏蔽
发表于 2008-10-11 09:57:51 | 显示全部楼层
好的。将这个帖子置COOL , 这样楼主的广告就被允许。
另:楼主能否将你的测试代码都打包上传上来? 谢谢。
 楼主| 发表于 2008-10-11 10:46:06 | 显示全部楼层
没问题
点击此处下载 ourdev_447491.zip(文件大小:4.15M) (原文件名:实验程序.zip)
发表于 2008-10-13 09:54:18 | 显示全部楼层
恩不错的,楼主的程序值得学习
 楼主| 发表于 2008-10-13 17:09:20 | 显示全部楼层
谢谢,大家多交流
我想以后能做一个直接软件解码mp3播放的STM32,可是这mp3怎么解码呢?我还一点不知道。
发表于 2008-10-13 22:30:13 | 显示全部楼层
网上有支持ARM7的MP3软件码库,记得NXP的LPC2xxx系列有一个应用笔记讲的是这个,有兴趣可以去NXP的网站找找。
STM32103xx是可以满足MP3软解的,只是支持的码率不清楚。听说ST计划在STM32上提供一个MP3的软解码库,至于何时公开就不清楚了。等不及得可以参照LPC2xxx的代码自己先移值。
最近忙其它的事情也就没去关心这事。做的板子选了RC,就因I2S接口。
 楼主| 发表于 2008-10-13 22:49:16 | 显示全部楼层
楼上的看来经验十足啊
多谢!
有空我去学习下。
发表于 2008-10-16 13:32:57 | 显示全部楼层
不错,谢谢啊!
我们准备做语音采集和播放,正好用上!谢谢了
出210入8汤圆
发表于 2008-11-5 12:37:18 | 显示全部楼层
好东东, mark。
发表于 2008-11-5 18:45:46 | 显示全部楼层
学习学习
发表于 2008-11-5 20:34:08 | 显示全部楼层
不错,有没有谁把这音乐录下来的给大家听一下。
发表于 2008-11-5 21:28:37 | 显示全部楼层
还以为可以解码mp3
发表于 2008-11-9 23:19:09 | 显示全部楼层
都在等软解码出来
发表于 2008-11-12 17:50:13 | 显示全部楼层
音效怎么样?想听听
发表于 2008-11-12 19:21:35 | 显示全部楼层
看看
发表于 2008-11-15 02:05:19 | 显示全部楼层
不错 超级51 什么时候有软解码  期待
 楼主| 发表于 2008-11-19 16:33:39 | 显示全部楼层
上次看见有人找我的联系方式:
这是我的邮箱:
 (原文件名:未命名.JPG)
本贴被 masbbx 编辑过,最后修改时间:2008-11-19,16:34:08.
发表于 2009-3-1 15:56:19 | 显示全部楼层
这个贴我要挖挖,因为我也要用stm32做mp3的软解码
发表于 2009-3-3 10:32:33 | 显示全部楼层
哈哈 我也顶一下
发表于 2009-3-12 13:46:33 | 显示全部楼层
顶一下楼主
发表于 2009-3-17 18:41:52 | 显示全部楼层
顶就一个字
发表于 2009-4-5 01:40:01 | 显示全部楼层
stm32做mp3的软解码,关注中。
发表于 2009-5-10 02:00:31 | 显示全部楼层
不错!外接喇叭能用吗?
发表于 2009-5-14 16:17:07 | 显示全部楼层
发表于 2009-5-20 08:09:37 | 显示全部楼层
MARK!
发表于 2009-12-17 13:52:07 | 显示全部楼层
各位帮帮忙啊!我下载正在做一个检测设备,上面用的是电磁式无源蜂鸣器,我想让电磁式无源蜂鸣器发出一个检测成功的那种声音,我上面用的单片机是PIC的,现在做的音乐太难听了(听着就想警报音),各位怎么实现啊!具体点了!谢谢了!
发表于 2010-3-7 14:06:53 | 显示全部楼层
MARK!      我的实验班 也有蜂鸣器 接了PWM  有空试试看
发表于 2010-3-7 17:11:10 | 显示全部楼层
mark
发表于 2010-4-2 07:36:55 | 显示全部楼层
mark
发表于 2010-4-9 22:31:04 | 显示全部楼层
【29楼】 sztxm
派别:
等级:------
来自:
不错!外接喇叭能用吗?
直接驱动估计不行,加一级功率放大(1-5w)应该就足够了
发表于 2010-6-8 18:29:51 | 显示全部楼层
谢谢,楼主分享的资料~~
好人
发表于 2010-10-27 09:51:31 | 显示全部楼层
MARK
发表于 2010-10-27 10:11:24 | 显示全部楼层
mark
发表于 2010-10-27 10:56:09 | 显示全部楼层
mark
发表于 2010-10-27 12:12:51 | 显示全部楼层
mark,但是感觉好像不适合拿来当做学习板呢
发表于 2010-10-27 12:33:51 | 显示全部楼层
楼主绝对好人,资料非常适合我这个初学者,谢谢分享!
发表于 2010-10-27 21:20:57 | 显示全部楼层
mark
发表于 2011-2-23 12:13:37 | 显示全部楼层
mark
发表于 2011-2-23 12:21:20 | 显示全部楼层
mark
发表于 2011-2-23 23:46:26 | 显示全部楼层
mark
发表于 2011-6-4 15:48:37 | 显示全部楼层
mark
出50入0汤圆
发表于 2011-6-4 15:54:15 | 显示全部楼层
mark
发表于 2011-6-16 21:01:01 | 显示全部楼层
好东西
发表于 2011-6-17 23:29:46 | 显示全部楼层
cool   记号!!!
发表于 2011-7-8 09:51:17 | 显示全部楼层
回复【楼主位】masbbx
dddddddd
发表于 2011-7-8 20:44:39 | 显示全部楼层
可以玩MP3了!
发表于 2011-7-8 22:46:04 | 显示全部楼层
mark
发表于 2011-7-12 16:59:35 | 显示全部楼层
好资料,收下了了,以后也买块板学习!
发表于 2012-3-30 22:15:38 | 显示全部楼层
不错。支持分享。
GMT+8, 2024-5-5 07:01
