发表于 2008-11-5 12:46:57
找到一个7.4 XXXX 下载地址: 正测试中
http://www.kamalan.com/202151/sec_11/p_3.aspx?lang=En
Proteus 7.4
Proteus is the best software that designed for simulating microcontrollers circuits. for first, you shuld drowe your circuit. then enter your HEX code on microcontroller and after that click on Run. finally, you see your behavior of circuit.
Installation:
1. Download proteus V7.4 software : Download (54.7M)
2. Install software on your computer.
3. Download crack of proteus : Download Crack
4. Open zip file and extract it in your directory (Over write previous files)
Run the program. I tested this software and the crack is valid and program ran without any problem.
本贴被 xininye 编辑过,最后修改时间:2008-11-05,12:48:32. |
