发表于 2008-11-10 16:14:01
点击此处下载 ourdev_492252.htm(文件大小:25K) (原文件名:Cosmic Software - Download.htm)
Download Software
Welcome to Cosmic Software Download Page. You will find here evaluation versions of most Cosmic tools and other free tools. Before downloading please note:
The evaluation software available on this page is designed to allow the user to build and debug a small application for evaluation purposes. If you need to port an existing project or build a more extensive project as part of your evaluation then we suggest you use a free 30 day time limited evaluation of the latest product which is available upon request. Please contact your local Cosmic office or distributor for 30 day evaluation requests.
Evaluation versions are completely free and do not require any registration to work.
For some targets, Cosmic provides a free size limited version supporting a larger application than the evaluation version. Some free versions may require registration for download and use as noted below.
The evaluation versions are NOT always the latest version that is available for purchase: for this reason we do not provide the version number for evaluation packages, although we guarantee that what you are evaluating is very similar to the latest version. (basically we rebuild evaluation versions only for major changes).
All evaluation packages include IDEA, compiler, and ZAP for Simulator. If you would like to evaluate software that works with hardware, please contact us to request a 30 day evaluation of the latest product for the specific hardware.
Manuals are included in PDF format.
本贴被 korren 编辑过,最后修改时间:2008-11-10,16:15:12. |
