发表于 2008-11-17 23:16:58
The nemo patch so far is the better solutions for the 7.4 SP3, previous test patch 2 will shutdown the isis during EVERY components adding from the library (when done selection and closing the library manager the whole isis shutdown).
But the nemo patch still seem not solving the random shutdown after some newly design file, below some possibility that make the isis close down (it may look like a software crash without any warning):
1. Add new component into the circuit
2. In schematic routing, when right click and try to copy a component.
3. Isis to Ares transfer
From all these random trigger it seem our cracker still not fully catching all the tricks use by those proteus crew so still (maybe) long way to go for the full patch.
Sure worth to wait coz so far this release seem WIP by many team (:
spasbyspas,
It seem like Nemo release another version of the patch (November 17, 2008, 3:33:57 PM), I'm not understand Russian, might need ur help to translate what different he fix on the latest patch.
Translate from Nemo last post:
"I suspect, that there will be one more release. At occurrence of a problem try to describe made actions as much as possible precisely. "
Seem like Nemo still work on the final patch as he request more precise describe on all the error that occur.
已经打过nemolic1补丁的朋友注意:
在\Program Files\Labcenter Electronics\Proteus 7 Professional里有个PatchWise.bak这是之前打补丁时的备份,将此文件立的两个文件夹复制到\Program Files\Labcenter Electronics\Proteus 7 Professional里覆盖原文件,就可以重新打补丁了 |
