MODBUS驱动设计与实现(DELPHI)
控件安装完后在DELPHI里调用此控件,打开源代码可直接修改,支持DELPHI5、6、7
初始化属性
constructor TModbusM.Create( AOwner: TComponent );
begin
inherited Create( AOwner );
// Initialize to default values
FComPortHandle := 0; // Not connected
FComPort := pnCOM2; // COM 2
FComPortBaudRate := br9600; // 9600 bauds
FComPortDataBits := db8BITS; // 8 data bits
FComPortStopBits := sb1BITS; // 1 stop bit
FComPortParity := ptNONE; // no parity
FComPortHwHandshaking := hhNONE; // no hardware handshaking
FComPortSwHandshaking := shNONE; // no software handshaking
FComPortInBufSize := 1028; // input buffer of 1024 bytes
FComPortOutBufSize := 1028; // output buffer of 1024 bytes
FComPortPollingDelay := 80; // poll COM port every 80ms
FOutputTimeout := 5000; // output timeout - 5000ms
FEnableDTROnOpen := false; // DTR high on connect
// Temporary buffer for received data
end;
//MODBUS发送
procedure TModbusM.Query;
var
CadenaCRC: word;
Cadena: TDataByte;
PCadena: PByte;
LCadena,i: Integer;
ByteTemp: Byte;
begin
if not connected then begin
FError:=11;
if Assigned(FOnError) then FOnError(Self, SErrorCodes[11] );
Exit;
end;
if FBusy then begin
FError:=10;
if Assigned(FOnError) then FOnError(self, SErrorCodes[11]);
exit;
end;
FBusy:=True;
FError:=0;
SetLength(ReadBuffer, 0);
//功能码1数据打包,依次累推可增加自己所需的其它功能码
case FFunction of
1: begin
Setlength(Cadena,8);
Cadena[0]:=FslaveId;
Cadena[1]:=FFunction;
Cadena[2]:=Hi(Foffset);
Cadena[3]:=Lo(Foffset);
Cadena[4]:=Hi(Fquantity);
Cadena[5]:=Lo(Fquantity);
CadenaCRC:=CRC(Cadena);
Cadena[high(Cadena)-1]:=lo(CadenaCRC);
Cadena[high(Cadena)]:=hi(CadenaCRC);
PCadena:=@Cadena[0];
LCadena:=High(Cadena)+1;
if SendData(PCadena,LCadena)=LCadena
then FTimer.Enabled:=True
else begin
FError:=9;
if Assigned(FOnError) then FOnError(Self, SErrorCodes[FError]);
FBusy:=False;
end;
end;
end;
//MODBUS接收
procedure TModbusM.Response( Sender: TObject; DataPtr: pointer; DataSize: integer );
var
CadenaCRC: Word;
PCadena: PByte;
i, LCadena : Integer;
ByteTemp: Byte;
begin
FTimer.Enabled:=False; //定时器停止
PCadena:=DataPtr;
LCadena:=DataSize;
//SetLength(Cadena, Legth(Cadena)+LCadena);
//Setlength(Cadena, LCadena);
for i:=0 to LCadena-1 do
begin
SetLength(ReadBuffer, Length(ReadBuffer)+1 );
ReadBuffer[Length(ReadBuffer)-1]:=PCadena^;
inc(PCadena);
end;
CadenaCRC:=CRC(ReadBuffer);
if (Lo(CadenaCRC)<>ReadBuffer[high(ReadBuffer)-1]) or (Hi(CadenaCRC)<>ReadBuffer[high(ReadBuffer)]) then
begin
FError:=9;
if Assigned(FOnError) then FOnError(Self, SErrorCodes[FError]);;
FBusy:=False;
Exit;
end;
//功能码1解析,依次累推可增加自己所需的其它功能码
case ReadBuffer[1] of
1: begin
if Fquantity Mod 8>0 then
ByteTemp:=(FQuantity div 8)+1
else ByteTemp:=Fquantity div 8;
if length(ReadBuffer)= ByteTemp+5 then
begin
SetLength(FReadValues, ReadBuffer[2]);
for i:=0 to ReadBuffer[2]-1 do
FReadValues:=ReadBuffer[3+i];
end
else begin
FError:= 4;
FBusy:=False;
exit;
end;
end;
end; |
