我的系统是mega用的是内部晶振,当我熔丝位配置成 内部1M 时程序运行正常,
其中 TCCR1B =_BV(ICNC1)|_BV(WGM12)|_BV(CS10);//TCNT1的计数时基为 1us
程序如下:TCCR1B 在main里面的设置是关键。
#include <avr/io.h>
#include <avr/interrupt.h>
#define Start_T1() TCCR1B|=_BV(CS10);TCNT1=0 //复位预计分频器并开启定时器T1
#define Stop_T1() TCCR1B&=~_BV(CS10) //关闭定时器T1
volatile unsigned char ICP_Parity=0;
volatile unsigned int Pulse_length=0;
volatile unsigned char IRReceiveCurrentBit=0;
volatile unsigned long IRcode;
volatile unsigned char Finish=0;
ISR(TIMER1_COMPA_vect)
IRReceiveCurrentBit=0; //重置IR接收位为第0位,为下次接收做准备
TIMSK&=~_BV(OCIE1A); //关闭溢出中断
TCCR1B|=_BV(ICES1); //设置输入捕获 上升沿有效
ICP_Parity = 0;
Stop_T1();
ISR(TIMER1_CAPT_vect)
if(ICP_Parity==0)
{ //上升沿进入这里
ICP_Parity = 1;
TIMSK|=_BV(OCIE1A);
TCCR1B&=~_BV(ICES1); //设置输入捕获 下降沿有效
Start_T1();
OCR1A =8000;
{ //下降沿进入这里
Stop_T1();
ICP_Parity=0;
TCCR1B|=_BV(ICES1);//设置输入捕获 上升沿有效
Pulse_length=ICR1;
if(IRReceiveCurrentBit==0)
if(Pulse_length>=3500&&Pulse_length<5500)// 如果是引导码 (4.5ms) 进入下一个bit的读取
IRReceiveCurrentBit++;
else if(IRReceiveCurrentBit<33)
IRcode>>=1;
if(Pulse_length<1900&&Pulse_length>1400) //判断是否为 1 ( 1.685 ms)
IRcode|=0x80000000;
if(IRReceiveCurrentBit==33)
Finish = 1;
Start_T1();
OCR1A =1000;
int main(void)
unsigned char i;
unsigned char b,c;
unsigned int temp;
unsigned char temperature_low=0;
unsigned char temperature_high=0;
unsigned char dp;
unsigned char show_data[5];
unsigned char led_on_off = 0;
OSCCAL = 0x9F;
asm("nop");asm("nop");asm("nop");asm("nop");
//这里lcd初始化程序,省略若干
DDRB |= (1<<2); //ds18s20
DDRD |= (1<<5); //led
DDRB &= ~(1<<0);//wireless
OCR1A =8000; //TCNT1 计数上限 设置IR接收超时 这里设置 8ms
TIMSK |=_BV(TICIE1);//开启输入捕获中断
TCCR1B|=_BV(ICES1);//输入捕获 上升沿有效
sei();
if(Finish == 1)
if( (unsigned char)(IRcode) == (unsigned char)( (unsigned char)(IRcode>>24)+(unsigned char)(IRcode>>16)+(unsigned char)(IRcode>>8) ) )
LCD_write_english_one(0,1,(unsigned char)(IRcode>>24) + '0');
//puthex(IRcode>>24);printstr(":");
//puthex(IRcode>>16);puthex(IRcode>>8);
//printstr("\n");
Finish = 0;
下面是问题:
当我把熔丝位配置成 内部8M后,通过修改 TCCR1B =_BV(ICNC1)|_BV(WGM12)|_BV(CS11); // 这里是8分频,希望还是得到T1的定时是1us,
上面的程序不变,就是变化了 TCCR1B =_BV(ICNC1)|_BV(WGM12)|_BV(CS11); 按道理,预分频 8M/8以后还是可以得到1us的,但是程序跑的就是不正常,现象就是 捕捉中断 不能正确捕捉,程序跑的也不正常。请大家帮帮我看看这个奇怪的问题。用的是winavr 20070525的版本,是不是编译器bug引起的?
以下蓝色文字由站长:armok 于:2009-01-10,06:23:34 加入。 你的原标题:“<font color=black>mega8 遇到一个超级奇怪的问题,请傻孩子,阿莫等高手进来看看,谢谢!” 不合符规定。请更改成能说明帖子大意的标题
试想一下,如果本论坛的帖子标题清一色的‘帮助!’,‘ADC求救!’等笼统的标题,你在阅读的过程中会造成许多麻烦。
所以本论坛规定:一定要起一个能说明帖子大意的标题。不允许“关于 AVR 的 ADC 使用!”这种笼统标题。作为标题,必须说明清楚:
①你是在请教问题,还是在介绍有关的知识?
②ADC的问题有许多,你是想说那方面的内容?
注意以上两点,标题应该改成如:“请教:ADC 可以不使用中断吗?”。
起一个能说明帖子大意的标题,除了减轻我们的帖子分类整理工作,还方便其它人阅读,节省大家的时间。
注:使用合格的标题,对你来说只是举手之劳,但却会为我们的管理工作提供很大的便利。谢谢你的支持。
