产品EOL测试中的EEPROM测试基本程序,第一次自己用IO模拟iic读写24C16
测试程序中利用了PB1上接了一个LED作为指示器,读写过程中作为提示,完成后作为PASS/FAIL的指示。
读写过程中LED闪亮,有点儿像硬盘读写指示灯,完成后全部PASS的话,就亮,否则就灭。
根据说明书,内部写数据最大所需时间为5ms,经过测试发现不同批次的AT24C16这个时间相差很大,相同批次也有一点差别,
但用5ms应该会比较可靠,缩短的话,可能会出现有些EEPROM写不进去。
仅供有需要的弟兄参考,很久没来发帖,贴上程序,拉高下帖高
#include <hidef.h> /* common defines and macros */
#include <mc9s12c32.h> /* derivative information */
#pragma LINK_INFO DERIVATIVE "mc9s12c32"
/* IIC operator */
//PS2 SCL only for out
//PS3 SDA in and out
#define scl_out PTS_PTS2
#define sda_out PTS_PTS3
#define sda_in PTIS_PTIS3
#define iic_out() DDRS_DDRS3=1
#define iic_in() DDRS_DDRS3=0
/**** for eeprom test ****/
//iic delay and eeprom internal write delay
void iic_delay(void){
uchar i;
for(i=0;i<0;i++);
//24C16 internal write time must more than 5mS
void ee_delay(void){
uint i;
for(i=0;i<5000;i++);
//start condition,SDA high to low when SCL high
void start(void){
iic_out();
sda_out=1;iic_delay();
scl_out=1;iic_delay();
sda_out=0;iic_delay();
scl_out=0;iic_delay();
//stop condition,SDA low to high when SCL high
void stop(void){
iic_out();
//data shift out to eeprom,use the SCL positive edge clock
void sh_out(uchar out){
uchar i;
iic_out();
for(i=0;i<8;i++){
if(out&0x80)sda_out=1;
else sda_out=0;
iic_delay();
scl_out=1;
iic_delay();
scl_out=0;
iic_delay();
out=out<<1;
//read ack from eeprom,
iic_in();
scl_out=1;
iic_delay();
while(sda_in);
scl_out=0;
//data shift in from eeprom,use the SCL negative edge clock
uchar sh_in(uchar ack_ee){
uchar i,temp;
temp=0;
iic_in();
//scl_out=0;
for(i=0;i<8;i++){
temp=temp<<1;
if(sda_in)temp=temp|0x01;
scl_out=1;
iic_delay();
scl_out=0;
iic_delay();
//ack for eeprom
iic_out();
if(ack_ee)sda_out=0;//ack
else sda_out=1;//no ack
iic_delay();
scl_out=1;
iic_delay();
scl_out=0;
return temp;
void write_ee_byte(uchar page,uchar addr,uchar byte_data){
page=page<<1;
start();
sh_out(0xa0|page);
sh_out(addr);
sh_out(byte_data);
stop();
ee_delay();
uchar read_ee_byte(uchar page,uchar addr){
uchar read_buf;
page=page<<1;
start();
sh_out(0xa0|page);
sh_out(addr);
start();
sh_out(0xa1|page);
read_buf=sh_in(0);
stop();
return read_buf;
void main(void) {
/* put your own code here */
//EnableInterrupts;
uchar rdata,page;
uint i,addr;
//init reg
DDRS_DDRS2=1;
DDRB_BIT1=1;
PORTB_BIT1=1;
i=0;
rdata=0;
//test EEPROM,write&read.
for(page=0;page<8;page++){
for(addr=0;addr<256;addr++){
write_ee_byte(page,addr,0x55);
if(read_ee_byte(page,addr)==0x55)i++;
if(i%8==0)PORTB_BIT1=!PORTB_BIT1;
if(i==2048)rdata=1;
i=0;
write_ee_byte(page,addr,0xaa);
if(read_ee_byte(page,addr)==0xaa)i++;
if(i==2048)rdata=rdata+1;
if(rdata==2)PORTB_BIT1=0;
else PORTB_BIT1=1;
for(;;) {} /* wait forever */
/* please make sure that you never leave this function */
