发表于 2004-12-28 21:54:39
//music.c
/* 广州天河双龙电子公司 */
/* http://www.sl.com.cn */
/* 电子音乐演示程序 */
/* 作者:ntzwq@wx88.net */
/* 2002年5月10日 */
/* 目标MCU:MEGA8 晶振:外部(EXT) 8MHZ */
//使用说明:音乐输出端口:PORTC.0,音乐数据存放
//于ATMEGA8的EEPROM存贮器中,可以使用music.exe
//程序通过RS232通信口进行修改。
//#include <iom8v.h>
//#include <macros.h>
//#include <eeprom.h>
#include <inttypes.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/signal.h>
#include <avr/wdt.h>
#include <avr/ina90.h>
#include <avr/eeprom.h>
#include "music.h"
//extern void uart_init(void);
//extern void isp(void);
#define __noinit__ __attribute__ ((section (".noinit"))) //变量不初始化
#define __eeprom__ __attribute__ ((section (".eeprom"))) //变量定义在eeprom中
#define __flash__ PROGMEM //变量定义在flash中(写法1)
//#define __flash__ __attribute__ ((section (".progmem"))) //变量定义在flash中(写法2)
//#define __flash__ __attribute__ ((progmem)) //变量定义在flash中(写法3)
//prg_uchar等
#define persistent __noinit__ //变量不初始化,相当于PICC的persistent
#define code PROGMEM //同__flash__,变量定义在flash中,相当于Keil C51的code
/* 音乐数据(卡秒莎) */
/* 四分之一拍为0x10, 二分之一拍为0x20, 一拍为0x40*/
/* 低1-1 2-2 3-3 4-4 5-5 6-6 7-7 */
/* 中1-8 2-9 3-A 4-B 5-C 6-D 7-E */
/* 高1-F*/
//#pragma data:eeprom
const __eeprom__ unsigned char sound[]={//正常节奏
// LA TI DO_H LA DO_H DO_H TI LA TI MI
0x66,0x27,0x68,0x26,0x28,0x28,0x27,0x26,0x47,0x43,
// TI DO_H RE_H TI RE_H RE_H DO_H TI LA LA
0x67,0x28,0x69,0x27,0x29,0x29,0x28,0x27,0x46,0x46,
0x4a,0x4d,0x4c,0x2d,0x2c,0x2b,0x2b,0x2a,0x29,0x4a,
0x46,0x20,0x4b,0x29,0x6a,0x28,0x27,0x23,0x28,0x27,
0x46,0x46,0x4a,0x4d,0x4c,0x2d,0x2c,0x2b,0x2b,0x2a,
0x29,0x4a,0x46,0x20,0x4b,0x29,0x6a,0x28,0x27,0x23,
0x28,0x27,0x46,0x46,0x00
const __eeprom__ unsigned char sound[]={//全短音
0x26,0x27,0x28,0x26,0x28,0x28,0x27,0x26,0x27,0x23,
0x67,0x28,0x29,0x27,0x29,0x29,0x28,0x27,0x26,0x26,
0x2a,0x2d,0x2c,0x2d,0x2c,0x2b,0x2b,0x2a,0x29,0x2a,
0x26,0x20,0x2b,0x29,0x2a,0x28,0x27,0x23,0x28,0x27,
0x26,0x26,0x2a,0x2d,0x2c,0x2d,0x2c,0x2b,0x2b,0x2a,
0x29,0x2a,0x26,0x20,0x2b,0x29,0x2a,0x28,0x27,0x23,
0x28,0x27,0x26,0x26,0x00
const __eeprom__ unsigned char sound[]={//全长音
0x66,0x67,0x68,0x66,0x68,0x68,0x67,0x66,0x67,0x63,
0x67,0x68,0x69,0x67,0x69,0x69,0x68,0x67,0x66,0x66,
0x6a,0x6d,0x6c,0x6d,0x6c,0x6b,0x6b,0x6a,0x69,0x6a,
0x66,0x60,0x6b,0x69,0x6a,0x68,0x67,0x63,0x68,0x67,
0x66,0x66,0x6a,0x6d,0x6c,0x6d,0x6c,0x6b,0x6b,0x6a,
0x69,0x6a,0x66,0x60,0x6b,0x69,0x6a,0x68,0x67,0x63,
0x68,0x67,0x66,0x66,0x00
const __eeprom__ unsigned char sound[]={//全低音
0x66,0x27,0x61,0x26,0x21,0x21,0x27,0x26,0x47,0x43,
0x67,0x21,0x62,0x27,0x22,0x22,0x21,0x27,0x46,0x46,
0x43,0x46,0x45,0x26,0x25,0x24,0x24,0x23,0x22,0x43,
0x46,0x20,0x44,0x22,0x63,0x21,0x27,0x23,0x21,0x27,
0x46,0x46,0x43,0x46,0x45,0x26,0x25,0x24,0x24,0x23,
0x22,0x41,0x46,0x20,0x44,0x22,0x63,0x21,0x27,0x23,
0x21,0x27,0x46,0x46,0x00
//#pragma data:data
/* 音阶表 */
const unsigned int TONETABLE[15]={DO,RE,MI,FA,SO,LA,TI,DO_H,
RE_H,MI_H,FA_H,SO_H,LA_H,TI_H,DO_HH};
/* 音阶重装常数 */
unsigned int toneconst;
/* 微秒级延时程序 */
void delay_us(int time)
do
time--;
while (time>1);
/* 毫秒级延时程序 */
void delay_ms(unsigned int time)
while(time!=0)
delay_us(1000);
time--;
//#pragma interrupt_handler timer1_ovf_isr:iv_TIMER1_OVF
//void timer1_ovf_isr(void)
SIGNAL(SIG_OVERFLOW1)
TCNT1=toneconst;
// PORTC^=1;
PORTC^=(1 << PC0);//PC0翻转产生发声频率
void music(void)
unsigned char temp,temp1;
unsigned int sound_add=0;
TCCR1A = 0x00;
TCCR1B =(1<<CS11);//8分频
// temp1=EEPROMread((int)&sound[sound_add]);
// temp1 = eeprom_read_byte(sound[sound_add]);
temp1 = eeprom_read_byte(sound + sound_add);
while(temp1!=0)//0为音乐结尾符
temp=temp1;
temp&=0x0f;//取低四位选择音调频率
if(temp!=0)
TIMSK|=(1<<TOIE1);//根据SOUNDTABLE中数据的低四位选择音调频率
temp--;
toneconst=TONETABLE[temp];//取选择音调频率
TCNT1=toneconst;//发声定时开始
temp=temp1;
temp>>=4;//取高四位
// temp&=0x0f;//废话!!!
// delay_ms(temp*129);//根据SOUNDTABLE中数据的高四位*5后,为音调持续时间(等待)
delay_ms(temp*138);//根据SOUNDTABLE中数据的高四位*5后,为音调持续时间(等待138mS较好些)
TIMSK&=~(1<<TOIE1);//发声结束
sound_add++;//乐谱音符指针+1
temp1 = eeprom_read_byte(sound + sound_add);//取一个音符或结尾符
delay_ms(1000);
/* 主程序 */
DDRC=0x01;
PORTC=0xff;
// uart_init();
sei();
music();
