* Board Support Packet of Microchip Chips
* FileName: BSP_DEBUG.C
* Dependencies: BSP_DEF.H
* BSP_FIFO.H
* BSP_INT.H
* BSP_UART.H
* P24FJ128GA006.H
* Processor: PIC24F
* Complier: Microchip C30 v2.01 or higher
* Company: Microchip Technology, Inc.
* Software License Agreement
* This software is owned by Microchip Technology Inc. ("Microchip")
* and is supplied to you for use exclusively as described in the
* associated software agreement. This software is protected by
* software and other intellectual property laws. Any use in
* violation of the software license may subject the user to criminal
* sanctions as well as civil liability. Copyright 2006 Microchip
* Technology Inc. All rights reserved.
* This software is provided "AS IS." MICROCHIP DISCLAIMS ALL
* WARRANTIES, EXPRESS, IMPLIED, STATUTORY OR OTHERWISE, NOT LIMITED
* TO MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, AND
* INFRINGEMENT. Microchip shall in no event be liable for special,
* incidental, or consequential damages.
* Author Date Comment
Robin Chen Dec/06 Original (Rev. 1.0)
#include "..\Include\BSP.H"
#include <p18f66j60.h>
* UART BAUD & BAUD RATE TABLE
rom WORD UART_BAUD_TBL[8][2] =
{UART_BAUD_1200 , UART_BAUD_RATE_1200 },
{UART_BAUD_2400 , UART_BAUD_RATE_2400 },
{UART_BAUD_4800 , UART_BAUD_RATE_4800 },
{UART_BAUD_9600 , UART_BAUD_RATE_9600 },
{UART_BAUD_19200 , UART_BAUD_RATE_19200 },
{UART_BAUD_38400 , UART_BAUD_RATE_38400 },
{UART_BAUD_57600 , UART_BAUD_RATE_57600 },
{UART_BAUD_115200, UART_BAUD_RATE_115200 }
* COM port related FIFO struction define, Tx & Rx Buffer
#pragma udata SEC_RXBUF // locate 0xA00
BYTE UARTRxBuf[512]; // Receive FIFO buffer
#pragma udata SEC_TXBUF // locate 0xC00
BYTE UARTTxBuf[512]; // Transfer FIFO buffer
#pragma udata
PBYTE RxFifo_Start;
PBYTE RxFifo_End;
PBYTE RxFifo_Read;
PBYTE RxFifo_Write;
PBYTE TxFifo_Start;
PBYTE TxFifo_End;
PBYTE TxFifo_Read;
PBYTE TxFifo_Write;
#pragma code // Return to default code section
//*******************************ADconvert
unsigned char i,j,CN;
union adres
unsigned int y1;
unsigned char adre[2];
}adresult;
BYTE Uart_Rx[128];
BYTE Uart_Rx_Len=0;
BYTE Uart_Frame=0;
* Function:
* PreCondition: None
* Input: None
* Output: None
* Side Effects: None
* Overview: None
* Note: None
BSP_STATUS UART_Init(BYTE Baud)
RCSTA1bits.SPEN = 0;// disable uart commutation
//calculate baud rate
SPBRGH1 = (BYTE)((UART_BAUD_TBL[Baud][1] & 0xFF00 )>>8);
SPBRG1 = (BYTE)(UART_BAUD_TBL[Baud][1] & 0x00FF );
//enable uart
RCSTA1bits.SPEN = 1;//Enable uart commutation
TxFifo_Start = (PBYTE)UARTRxBuf;
TxFifo_End = (PBYTE)UARTRxBuf + sizeof(UARTRxBuf);
TxFifo_Read = (PBYTE)UARTRxBuf;
TxFifo_Write = (PBYTE)UARTRxBuf;
RxFifo_Start = (PBYTE)UARTTxBuf;
RxFifo_End = (PBYTE)UARTTxBuf + sizeof(UARTTxBuf);
RxFifo_Read = (PBYTE)UARTTxBuf;
RxFifo_Write = (PBYTE)UARTTxBuf;
return STATUS_SUCCESS;
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
BSP_STATUS UART_Read(PBYTE pBuffer,WORD wCount )
while( wCount-- > 0 )
// read from the FIFO, and pointe to the next
*pBuffer++ = *RxFifo_Read;
INTCONbits.GIEL = 0; // disable low level priority interrupt
RxFifo_Read++;
INTCONbits.GIEL = 1; // enable low level priority interrupt
// check if it is the bottom of FIFO
if( RxFifo_Read >= RxFifo_End )
RxFifo_Read = RxFifo_Start;
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
BSP_STATUS UART_Write(PBYTE pBuffer,WORD wCount )
// write to the FIFO, and pointe to the next
*TxFifo_Write = *pBuffer++;
TxFifo_Write++;
if( TxFifo_Write >= TxFifo_End )
TxFifo_Write = TxFifo_Start;
PIE1bits.TX1IE = 1; // enable
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
WORD UART_BlankNum(void)
WORD wBlankNum;
if( TxFifo_Write == TxFifo_Read )
wBlankNum = TxFifo_End - TxFifo_Start - 1;
else if( TxFifo_Write > TxFifo_Read )
wBlankNum = TxFifo_End - TxFifo_Start + TxFifo_Read - TxFifo_Write - 1;
wBlankNum = TxFifo_Read - TxFifo_Write - 1;
return wBlankNum;
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
WORD UART_HoldNum(void)
WORD wHoldNum;
if( RxFifo_Write == RxFifo_Read ) //如果BUFFER中没有包,或在写帧数据,就不要发包
wHoldNum = 0;
else if( RxFifo_Write > RxFifo_Read )
wHoldNum = RxFifo_Write - RxFifo_Read;
wHoldNum = RxFifo_End - RxFifo_Start + RxFifo_Write - RxFifo_Read;
return wHoldNum;
* Function: void _ISR _U1RXInterrupt(void)
* Input: None
* Output:
* Overview: None
* Note: None
#pragma interruptlow UART_Handler
void UART_Handler(void)
BYTE data;
BYTE i;
// TX interrupter handler
if(PIR1bits.TX1IF)
PIE1bits.TX1IE = 0; // disable
TXREG1 = *TxFifo_Read++;
if( TxFifo_Read >= TxFifo_End )
TxFifo_Read = TxFifo_Start;
// RX interrupter handler
if(PIR1bits.RC1IF)
data = RCREG1;
//RCSTA1bits.SPEN = 0;// disable uart commutation
Uart_Rx[Uart_Rx_Len]=data;
if(Uart_Rx[0]==0x02)
Uart_Rx_Len++;
if( (Uart_Rx_Len == Uart_Rx[3]+5) && (Uart_Rx_Len>=0x05) ) //一个桢类型,两个命令,一个数据长度,一个校验位
for( i=0; i < Uart_Rx_Len;i++)
*RxFifo_Write++ = Uart_Rx;
if((RxFifo_Write)>= RxFifo_End )
RxFifo_Write = RxFifo_Start;
Uart_Rx[0]=0;
Uart_Rx_Len = 0;
Uart_Rx_Len=0;
Uart_Rx[0]=0;
//RCSTA1bits.SPEN = 1;//Enable uart commutation
//*RxFifo_Write++ = data;
//if( RxFifo_Write >= RxFifo_End )
//RxFifo_Write = RxFifo_Start;
#pragma code LowVector=0x18
void LowVector (void)
_asm goto UART_Handler _endasm
以上的这样会死-----------------------------------------------------------------------------------------没办法啊,去掉缓冲环后,实验证明就不死了,,,,,如下
* BSP_FIFO.H
* BSP_INT.H
* BSP_UART.H
* P24FJ128GA006.H
* Processor: PIC24F
#include "..\Include\Compiler.h"
BYTE UARTRxBuf[256]; // Receive FIFO buffer
BYTE UARTTxBuf[256]; // Transfer FIFO buffer
#pragma udata
PBYTE RxFifo_Start;
PBYTE RxFifo_End;
PBYTE RxFifo_Read;
PBYTE RxFifo_Write;
PBYTE TxFifo_Start;
PBYTE TxFifo_End;
PBYTE TxFifo_Read;
PBYTE TxFifo_Write;
BOOL LED_TEST;
union adres
unsigned int y1;
}adresult;
BYTE Uart_Rx[128];
BYTE Uart_Tx[128];
BYTE Uart_Rx_Len=0;
BYTE Uart_Frame=0;
BYTE UART_Rx_Lensave;
BYTE Tx_Len;
BYTE Tx_Now;
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
//enable uart
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
unsigned char i=0;
RxFifo_Read++;
*pBuffer++ =Uart_Rx[i++] ;
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
unsigned char i=0;
Tx_Len = wCount;
Tx_Now = 0;
LED_TEST=!LED_TEST;
BUTTON_IO = LED_TEST;
TxFifo_Write++;
Uart_Tx[i++]=*pBuffer++;
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
WORD wBlankNum;
return wBlankNum;
* Function:
* Input: None
* Output: None
* Overview: None
* Note: None
WORD wHoldNum;
wHoldNum = 0;
wHoldNum = UART_Rx_Lensave;
UART_Rx_Lensave = 0;
return wHoldNum;
* Input: None
* Output:
* Overview: None
* Note: None
BYTE data;
BYTE i;
if(PIR1bits.TX1IF)
if((Tx_Len !=0)&&(Tx_Now<Tx_Len))
TXREG1 = Uart_Tx[Tx_Now];
Tx_Now++;
PIE1bits.TX1IE = 0;
Tx_Len = 0;
if(PIR1bits.RC1IF)
data = RCREG1;
if((Uart_Rx[0]==0x02)&&(Uart_Rx_Len<=127)) //单包大小最大127。新增加+++++++++++
Uart_Rx_Len++;
UART_Rx_Lensave=Uart_Rx_Len;
Uart_Rx[0]=0;
Uart_Rx_Len = 0;
Uart_Rx_Len=0;
Uart_Rx[0]=0;
哪个能发现原因?????? |
