发表于 2009-2-22 11:23:41
给你参考一下,适用24c02 24c01A
#define SDA P2.1
#define SDA_DIR PM2.1
#define SCL P4.2
//port direction
#define INPUT 1
#define OUTPUT 0
//for AT2402 write or read command
#define W_ADD_COM 0xA0 //1010 A2 A1 A0 0
#define R_ADD_COM 0xA1 //1010 A2 A1 A0 1
//the first address of data writed to 2402
#define RomAddress 0x02
// Function: I2C operation for at2402
//start I2C
void I2CStart(void)
SCL = 0;
SDA = 1;
SCL = 1;
NOP();NOP();
SDA = 0;
NOP();NOP();
SCL = 0;
//stop I2C
void I2CStop(void)
SDA = 0;
SCL = 1;
NOP();
NOP();
SDA = 1;
//ask
void I2CAck(void)
SDA = 0;
SCL = 1;
NOP();
NOP();
SCL = 0;
SDA = 1;
//noack
void I2CNoAck(void)
SDA = 1;
SCL = 1;
NOP();
NOP();
SCL = 0;
char I2CTestAck(void)
char ErrorBit;
SDA = 1;
SDA_DIR = INPUT; //change SDA direction to input
SCL = 1;
NOP();NOP();
NOP();NOP();
NOP();NOP();
ErrorBit = SDA; // 0 is ask; 1 is noack
SCL = 0;
SDA_DIR = OUTPUT; //change SDA direction to output
return(ErrorBit);
/* write one byte to I2C */
void I2CWrite8Bit(unsigned char data)
unsigned char i;
//SCL must is low level
for(i = 8; i != 0; i--)
if(data & 0x80)
SDA = 1;
SDA = 0;
SCL = 1;
data = data << 1;
SCL = 0;
/* read one byte from I2C */
unsigned char I2CRead8Bit(void)
unsigned char i, rbyte = 0;
SCL = 1;
rbyte = rbyte << 1;
if(SDA)
rbyte |= 0x01;
rbyte |= 0x00;
SCL = 0;
return(rbyte);
void write2402(void)
I2CStart(); //start
I2CWrite8Bit(W_ADD_COM); //write the address of AT2401a
if(I2CTestAck() == 1) goto i2cerror;
I2CWrite8Bit(RomAddress);
I2CWrite8Bit(67);
I2CWrite8Bit(12);
I2CWrite8Bit(134);
I2CWrite8Bit(12);
I2CStop();
Delay10us(1000);
return;
i2cerror:
I2CStop();
void Read24c02(unsigned char *RamAddress, unsigned char bytes)
I2CStart();
if(I2CTestAck() == 1) goto i2cend;
I2CStart();
I2CWrite8Bit(R_ADD_COM);
while(bytes != 0)
*RamAddress = I2CRead8Bit();
I2CAck(); //
RamAddress++;
bytes--;
I2CNoAck(); //
i2cend:
I2CStop(); //
