发表于 2009-2-20 17:59:56
用DEMO 编译的结果:
Build E:\MPLAB\MPLAB\IPU_RXFIRST\IPU for device 18F25J10
Using driver D:\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18.exe
Make: The target "E:\MPLAB\MPLAB\IPU_RXFIRST\ipu.p1" is out of date.
Executing: "D:\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18.exe" --pass1 E:\MPLAB\MPLAB\IPU_RXFIRST\ipu.c -q --chip=18F25J10 "-ID:\HI-TECH Software\PICC-18\pro\9.61\include" -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Warning [359] E:\MPLAB\MPLAB\IPU_RXFIRST\ipu.c; 1279.6 illegal conversion between pointer types
Warning [359] E:\MPLAB\MPLAB\IPU_RXFIRST\ipu.c; 1297.12 illegal conversion between pointer types
Executing: "D:\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18.exe" -oIPU.cof -mIPU.map --summary=default --output=default ipu.p1 --chip=18F25J10 "-ID:\HI-TECH Software\PICC-18\pro\9.61\include" -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
HI-TECH C PRO for the PIC18 MCU Family candidate build 4040 V9.63PL2
Copyright (C) 1984-2009 HI-TECH SOFTWARE
licensed for evaluation purposes only
this licence will expire on Fri, 10 Apr 2009
Memory Summary:
Program space used 1CF7h ( 7415) of 7FF8h bytes ( 22.6%)
Data space used 152h ( 338) of 400h bytes ( 33.0%)
EEPROM space None available
ID Location space used 0h ( 0) of 8h nibbles ( 0.0%)
Configuration bits used 0h ( 0) of 4h words ( 0.0%)
Loaded E:\MPLAB\MPLAB\IPU_RXFIRST\IPU.cof.
********** Build successful! **********
用PATCH后的结果:
Make: The target "E:\MPLAB\MPLAB\IPU_RXFIRST\ipu.p1" is up to date.
Serial number: HCPIC18P-DEMO
Memory Summary:
Program space used 443Fh ( 17471) of 7FF8h bytes ( 53.3%)
Data space used 177h ( 375) of 400h bytes ( 36.6%)
********** Build successful! ********** |
