发表于 2009-3-31 01:51:49
Name:Futaba 6EX 6-Channel 2.4GHz Transmitter/Receiver
Price: $219.99
Standard Programming Features:
Trainer function-transmitter can be master or student, compatible with other Futaba systems
Six model memory
Servo reversing
End point adjustment
Airplane or heli programming
Dual Rate /Exponential for ailerons, rudder and elevator
Fail Safe-safety throttle setting in case of transmitter signal loss
Battery Fail Safe-safety throttle setting in case of signal loss
Stick Mode-Choose from Mode 1-Mode-4
Changeable Throttle Stick-ratchet for airplanes or smooth for helis
Adjustable Stick Length
Airplane Features:
Programmable Mixing (1 & 2) any two channels can be combined
Pre-Programmed Throttle Cut for safely shutting off engine
Wing mixing for flaperon, flap trim, V-tail and elevon
Helicopter Functions:
Three swashplate types
Five-Point Normal and Idle Up Throttle/Pitch Curves
Revo, Gyro and Swash to Throttle mixing
Swash AFR Adjustable Function Rate for use w/ 3S or 3E swash types
INCLUDES:
Futaba 6EX Transmitter
NT8F600B 9.6V 600mAh Transmitter Battery, FUTM1440
FBC-19B(4) Battery Charger, FUTM1830
R606FS Receiver, FUTL7635
Switch Harness-J Style Connector, FUTM4350
Neck Strap
REQUIRES:
Servos and receiver battery depending on type of aircraft
SPECS: Transmitter;
Power Supply: 9.6V
Current Drain: 170mA
SPECS: Receiver;
Size: 1.6 x 1.1 x 0.35" (40 x 27 x 9mm)
Power Requirement: 4.8 - 6V
Current Drain: 80mA (at no signal)
Weight: 0.35oz (10g) with case
0.25oz (7g) without case |
