兄弟们,我的控制线用RB0—RB2驱动正常,为什么换成RE0—RE2就不正常了?四线驱动的下面有程序
#include <pic.h>
//#include <pic1687x.h>
//#define _16F877
__CONFIG (HS & PROTECT & PWRTEN & BOREN & WDTDIS & DEBUGEN);
#define uint8 unsigned char
#define int8 char
#define uint16 unsigned int
#define int16 int
#define uint32 unsigned long
#define int32 long
#define LCD_CMD_WR (1 << 0)
#define LCD_DATA_WR (1 << 0)
#define LCD_BUSY_RD (1 << 1)//0x02
#define LCD_DATA_RD 0x03
//LCD Commands
#define LCD_CLS 0x01
#define LCD_HOME 0x02
#define LCD_SETMODE 0x04
#define LCD_SETVISIBLE 0x08
#define LCD_SHIFT 0x10
#define LCD_SETFUNCTION 0x20
#define LCD_SETCGADDR 0x40
#define LCD_SETDDADDR 0x80
#define E_PIN_MASK (1 << 2)
#define DATA_DDR_ON DATA_DDR&=0x0F// = 0x00
#define DATA_DDR_OFF DATA_DDR|=0xF0// = 0xFF
#define DATA_PORT_ON DATA_PORT|=0xF0// = 0xFF
#define DATA_PORT_OFF DATA_PORT&=0x0F// = 0x00
#define DATA_DDR TRISD
#define DATA_PORT PORTD
#define CORTROL_DDR TRISE
#define CORTROL_PORT PORTE
uint8 flag;
uint8 pacmanopen[] = {0x0E,0x07,0x03,0x01,0x03,0x07,0x0E,0x00,'\n'};
uint8 pacmanshut[] = {0x00,0x0F,0x1F,0x01,0x1F,0x0F,0x00,0x00,'\n'};
uint8 text[] = {'4','-','B','i','t',' ','L','C','D',' ','M','o','d','e', ' ','\n'};
void delay_us (uint16 disp_time) //
do
disp_time--;
while(disp_time>0);
void delay_ms (uint16 disp_time)
while(disp_time>0)
delay_us(1000);
disp_time--;
void wrcmd (uint8 cmdcode)
//lcd_wait();
DATA_DDR&=0x0F;
DATA_PORT&=0x0F;
DATA_PORT |= (cmdcode & 0xF0); // Get the most significant nibble first.
//CORTROL_PORT = CORTROL_DDR = 0;
CORTROL_DDR &= ~(1 << 0);
CORTROL_DDR &= ~(1 << 1);
CORTROL_DDR &= ~(1 << 2);
CORTROL_PORT &= ~(1 << 0);
CORTROL_PORT &= ~(1 << 1);
CORTROL_PORT &= ~(1 << 2);
CORTROL_PORT &= ~LCD_CMD_WR; // Specify a command write operation.
CORTROL_PORT |= E_PIN_MASK; // Toggle the 'E' pin to send the command.
asm("NOP");asm("NOP");asm("NOP");
CORTROL_PORT &= ~E_PIN_MASK;
DATA_DDR&=0x0F;
DATA_PORT&=0x0F;
DATA_PORT |= ((cmdcode << 4)&0xF0); // Repeat for least significant nibble.
// Call the wait routine.
void wrdata (uint8 data)
//lcd_wait();
DATA_DDR&=0x0F;
DATA_PORT&=0x0F;
DATA_PORT |= (data & 0xF0); // Get the most significant nibble first.
//CORTROL_PORT = LCD_DATA_WR; // Specify a data write operation.
CORTROL_PORT |= (1 << 0);
DATA_DDR&=0x0F;
DATA_PORT&=0x0F;
DATA_PORT |= ((data << 4)&0xF0); // Repeat for least significant nibble.
CORTROL_PORT &= ~E_PIN_MASK; // Call the wait routine.
void lcd_set_xy( uint8 x, uint8 y ) //写地址函数
uint8 address;
if (y == 0)
address = 0x80 + x;
else if (y == 1)
address = 0xc0 + x;
else if (y == 2)
address = 0x94 + x;
address = 0xD4 + x;
wrcmd( address);
void lcd_write_onechar(uint8 X1,uint8 Y1,uint8 data) //列x=0~15,行y=0,1
lcd_set_xy( X1, Y1 ); //写地址
wrdata(data);
void lcd_init ()
DATA_DDR_ON;
DATA_PORT_ON;
//wrcmd(0x28);
wrcmd(0x28);
wrcmd(0x28);
wrcmd(0x0c);
wrcmd(0x01);
void LCD_write_string(uint8 X,uint8 Y,uint8 *s) //列x=0~15,行y=0,1
lcd_set_xy( X, Y ); //写地址
while (*s) // 写显示字符
wrdata( *s );
s ++;
ADCON1=0x87; //转换结果右移,及ADRESH 寄存器的高6 位为"0"
lcd_init(); // Initialise the LCD Display
lcd_write_onechar(0,1,0x38);
for (;;) // Loop Forever.
LCD_write_string(0,0,text);
