void TIMEA_set(uint n)
uint a; (错误指向处)
for (a=n;a>0;a--)
_NOP();
_NOP();
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR (警告指向处)
__interrupt void Timer_A (void)
P1IE = 0x00; //close pord int
ReadID();
Calculate_CRC16(Command_Send_Buf,8); //Calculate_CRC16 //8byte
SETBP12(); //open vo1
TIMEA_set(10);
Set_DCO(12); //set dco 12mhz
SEND_64ID();
Timer_con1 = Timer_con1+1;
CPLP14();
Set_DCO(1); //set dco 1mhz
Count++; (警告指向处)
if (Count==10)
Count=0;
CCR0 = (5000+(SendTimer_Buf[Count]*8));//5000
Timer_con1 = 0x00;
P1IE = 0x01; //open pord int
编译出错:
Building configuration: RF_ID - Debug
Updating build tree...
RF_IDSOFT.c
Error[Pe065]: expected a ";" G:\E\www\标签程序\RF_IDSOFT半有源6C协议8byte 25ms\RF_IDSOFT.c 786
Warning[Pe606]: this pragma must immediately precede a declaration G:\E\www\标签程序\RF_IDSOFT半有源6C协议8byte 25ms\RF_IDSOFT.c 799
Warning[Pe012]: parsing restarts here after previous syntax error G:\E\www\标签程序\RF_IDSOFT半有源6C协议8byte 25ms\RF_IDSOFT.c 824
Total number of errors: 1
Total number of warnings: 2
请问是什么原因? |
