发表于 2009-6-25 14:26:04
1 - It might have side effects, like slowing down your download speed or affecting your performance on other softwares. (In my case, it didn't change anything)
2 - If you're not sure about what you're doing, just don't do it. I don't want to be responsible because you crashed your computer in some way because you wasted your registry.
2.1 - Seriously, if you don't know what you're doing, don't do it. It will be fixed in one or two weeks anyway. (and the official fix won't have any impact on other softwares)
3 - If you don't have the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSMQ\ directory, you can download and apply this file to your registry.
4 - Windows Vista users might want to check this post too.
Source - Elitistjerks.com
"1 - TcpAckFrequency - NOTE if you are running Windows Vista this setting may not have any effect - a hotfix is needed which i'm tracking down. This works fine under Windows XP
Type "regedit" in windows "run.." dialog to bring up registry menu
Then find:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\
There will be multiple NIC interfaces listed in there, find the one you use to connect to the internet, there will be several interfaces listed (they have long names like {7DBA6DCA-FFE8-4002-A28F-4D2B57AE8383}. Click each one, the right one will have lots of settings in it and you will see your machines IP address listed there somewhere. Right-click in the right hand pane and add a new DWORD value, name it TcpAckFrequency, then right click the entry and click Modify and assign a value of 1.
You can change it back to 2 (default) at a later stage if it affects your other TCP application performance. it tells windows how many TCP packets to wait before sending ACK. if the value is 1, windows will send ACK every time it receives a TCP package.
2 - TCPNoDelay
This one is pretty simple (Discussed here)
Then find:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSMQ\Parameters
Right-click in the right hand pane and add a new DWORD value, name it TCPNoDelay, then right click the entry and click Modify and assign a value of 1.
Click Ok and close the registry editor, then reboot your PC." |
