发表于 2009-7-6 10:42:57
这是我的一个项目用9234编译的信息供参考
SEGMENT SPACE START ADDRESS END ADDRESS SIZE TYPE ALIGN
CHECKSUM 1A1A - 1A1B 2 rel 0
Symbol Checksum Memory Start End Initial value
__checksum 0xb1b2 CODE 0000 - 0021 0x0000 (#0x0000)
CODE 0040 - 0084
CODE 0086 - 1A19
CODE 1A1C - 1CFF
6 575 bytes of CODE memory (+ 683 range fill )
213 bytes of DATA memory (+ 42 absolute )
110 bytes of CONST memory (+ 25 absolute )
连接文件(保留mini2仿真空间)
// Define CPU
-c78000
// Size of the stack.
// Remove comment and modify number if used from command line.
//-D_CSTACK_SIZE=80
// SFR register address for code bank switching.
// Remove one of the comments and optionally modify bank register
// address if used from command line.
// "Standard" code model, no banked functions
//-D_CODEBANK_REG=0
// Size of the heap.
//-D_HEAP_SIZE=400
// Used by DLIB only
// Define the format functions used by printf/scanf.
// Default is full formatting.
// Remove appropriate comment(s) to get reduced formatting
// if used from command line.
//-e_PrintfTiny=_Printf
//-e_PrintfSmall=_Printf
//-e_PrintfLarge=_Printf
//-e_ScanfSmall=_Scanf
//-e_ScanfLarge=_Scanf
// Define if row buffering should be used by terminal output.
// Default is no buffering.
// Remove comment to get buffered terminal output if used from command line.
//-e__write_buffered=__write
// Used by CLIB only
//-e_small_write=_formatted_write
//-e_medium_write=_formatted_write
//-e_medium_read=_formatted_read
// Allocate the read only segments that are mapped to ROM.
// Interrupt vector segment.
-Z(CODE)INTVEC=0000-0021
// CALLT vector segment.
-Z(CODE)CLTVEC=0040-007F
// OPTION BYTES segment.
-Z(CODE)OPTBYTE=0080-0084
// Startup, Runtime-library, Non banked, Interrupt
// and CALLT functions code segment.
-Z(CODE)RCODE,CODE=0086-1CFF
// Data initializer segments.
-Z(CONST)CHECKSUM,NEAR_ID,SADDR_ID,DIFUNCT=0086-1CFF
// Constant segments
-Z(CONST)CONST,SWITCH=0086-1CFF
// Allocate the read/write segments that are mapped to RAM.
// Workseg and short address data segments.
-Z(DATA)WRKSEG=FE20-FEFF
-Z(DATA)SADDR_I,SADDR_Z,SADDR_N=FE20-FEFF
// Near data and heap segments.
-Z(DATA)NEAR_I,NEAR_Z,NEAR_N,HEAP+_HEAP_SIZE=FE00-FEFF
// Stack segment.
-Z(DATA)CSTACK+_CSTACK_SIZE=FE00
// Select the output file format if used from command line.
// Remove comment to select the file format if used from command line.
//-Fdebug
// End of File
