为了计算"加速度计"的值而抓取它的信号, 希望能有稳定准确的占空比!
但找了很多数据, 都查不出问题所在...
麻烦请教,谢谢!!
系统clk: 1M Hz , 预分频: clk/8 ,
code:
#include <avr/io.h>
#include <avr/iom128.h>
#include <avr/interrupt.h>
#include "RS-232.h"
#define fOSC 1000000 // System clock
#define BUAD 4800 // buad rate : 4800
#define UBRR fOSC/16/BUAD-1
unsigned int temp_rising = 0;
unsigned int temp_falling = 0;
unsigned int temp_l = 0;
unsigned int temp_h = 0;
unsigned int pwm = 0;
ISR(TIMER1_CAPT_vect)
switch(TCCR1B)
case 0x82:
temp_l = ICR1L;
temp_h = ICR1H;
temp_rising = ICR1;
TCCR1B = TCCR1B & 0xBF; //TCCR1B = 0x82, 改为下降缘触发
TIFR = 0x20;
case 0xC2:
temp_l = ICR1L;
temp_h = ICR1H;
temp_falling = ICR1;
TCCR1B = TCCR1B | 0x40; //TCCR1B = 0xC2, 改为上升缘触发
TIFR = 0x20;
pwm = temp_falling - temp_rising;
USART_Transmit(pwm);
int main(void)
DDRD = 0x00;
TCCR1B = (1 << ICNC1)|(1 << ICES1)|(1 << CS11); //初始为上升缘触发
TIMSK = (1 << TICIE1);
TIFR = (1 << ICF1);
USART_Init(UBRR);
sei();
void USART_Init(unsigned int ubrr1)
// Set baud rate //
UBRR1H = (unsigned char)ubrr1 >> 8;
UBRR1L = (unsigned char)ubrr1;
UCSR1B = (1 << RXEN1)|(1 << TXEN1); // Enable receiver, transmitter //
UCSR1C = (1 << UCSZ11)|(1 << UCSZ10); // Set frame format: 8 data, 1 stop bit //
void USART_Transmit(unsigned int data)
while(!(UCSR1A & (1 << UDRE1))); // Wait for empty transmit buffer //
UDR1 = data; // Put data into buffer, sends the data //
