这是从杜洋老那里的PG12864的51测试程序,我把改成在AVR上运行,再总是调试不通,请大家帮看一下,指出屏不显示的问题,以给我一点思路
在ICC-AVR 6.30调试,8M外部晶振
//PG12864参考程序(st7920) 主程序
/* PG12864系列测试程序 1.0for mega16 */
/* Designed by ourembed.com */
/* 2009.09.23 */
//ICC-AVR application builder : 2009-9-17 18:33:11
// Target : M16
// Crystal: 8.0000Mhz
#include <iom16v.h>
#include <macros.h>
#include "12864.H"
void port_init(void)
PORTA = 0xFF;
DDRA = 0xFF;
PORTB = 0xFF;
DDRB = 0xFF;
PORTC = 0xFF; //m103 output only
DDRC = 0xFF;
PORTD = 0xFF;
DDRD = 0xFF;
//call this routine to initialise all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialised
unsigned char lx = 32,i;
init_devices();
init_lcd(); // LCM12864 初始化
while(1){
LCM12864_Disp_Bitmap_12864(60,doyleee); //显示 LOGO 图像
Delay(1000); //延时 1 秒
Clear_Screen(); //清除屏幕
for(i=0;i<7;i++)
{ //显示字符串“Dy12864”
LCM12864_Disp_Char_x_16(8,8,1,lx+8*i,nAsciiDot+16*i); //显示“Dy12864”,从第 1 页第 32 列
Delay(1000);
LCM12864_Disp_Char_x_16(12,16,4,46,huan1); //显示“欢”,在第 4 页第 46 列
Delay(1000);
LCM12864_Disp_Char_x_16(12,16,4,66,ying2); //显示“迎”,在第 4 页第 66 列
Delay(1000);
12864.H头文件
#include "font.h"
#define LCD_E (1 <<7) // PD7----E
#define LCD_DI (1 <<6) //PD6----DI
#define LCD_RW (1 <<5) // PD5----RW
#define LCD_RST (1 <<4) // PD4----RST
#define LCD_CS2 (1 <<3) // PD3----CS2
#define LCD_CS1 (1 << 2) // PD2----CS1
#define LCD_PORT PORTD //PD口连接到了5个控制脚,具体定义如上
#define LCD_DDDR DDRD
#define LCD_SET_CS1() (LCD_PORT |= LCD_CS1) // 位置位,输出1
#define LCD_SET_CS2() (LCD_PORT |= LCD_CS2)
#define LCD_SET_RST() (LCD_PORT |= LCD_RST)
#define LCD_SET_DI() (LCD_PORT |= LCD_DI)
#define LCD_SET_RW() (LCD_PORT |= LCD_RW)
#define LCD_SET_E() (LCD_PORT |= LCD_E)
#define LCD_CLEAR_CS1() (LCD_PORT &= ~LCD_CS1) // 位清零,输出0
#define LCD_CLEAR_CS2() (LCD_PORT &= ~LCD_CS2)
#define LCD_CLEAR_RST() (LCD_PORT &= ~LCD_RST)
#define LCD_CLEAR_DI() (LCD_PORT &= ~LCD_DI)
#define LCD_CLEAR_RW() (LCD_PORT &= ~LCD_RW)
#define LCD_CLEAR_E() (LCD_PORT &= ~LCD_E)
#define LCD_DATA_OUT PORTA //LCD数据输出口
#define LCD_DATA_IN PINA //LCD数据输出口
#define LCD_DDR DDRA //LCD数据口方向
/* Define the register command code */
#define Disp_On 0x3f
#define Disp_Off 0x3e
#define LCM12864_START_ROW 0xc0 // 显示起始行 0,可以用 LCM12864_START_ROW+x 设置起始行。(x<64)
#define LCM12864_PAGE_START_ADDR 0xb8 // 页起始地址,可以用 LCM12864_PAGE_START_ADDR+x 设置当前页。(x<8)
#define LCM12864_COL_START_ADDR 0x40 // 列起始地址,可以用 LCM12864_COL_START_ADDR+x 设置当前列。(x<64)
/*定义 LCM12864 的状态屏蔽码
在 BUSY 和 REST 状态时,除读状态指令外,其他指令均不对 LCM12864 产生作用。
在对 LCM12864 操作之前要查询 BUSY 状态,以确定是否可以对 LCM12864 进行操作。*/
#define LCM12864_STATUS_BUSY 0x80 // LCM12864 忙状态屏蔽码
#define LCM12864_STATUS_DISP_OFF 0x20 // LCM12864 显示关闭状态屏蔽码
#define LCM12864_STATUS_REST 0x10 // LCM12864 复位状态屏蔽码
void Delay(unsigned int t); //延时程序
void write_com(unsigned char cmdcode); //写命令到LCD
void write_data(unsigned char Dispdata); //写数据到LCD
unsigned char LCM12864_TestBusy(void); //测试忙
void Clear_Screen(void); //清除屏幕
void init_lcd(void); //初始化LCD屏
unsigned char read_data(void);//读LCD数据
void LCM12864_Fill_Screen(unsigned char t,unsigned char LCM12864_FillData);
void LCM12864_Disp_Bitmap_12864( unsigned char t,unsigned char const *bitmap_12864);//设置涮屏速度(为 1 不涮屏,默认为 60)
void LCM12864_Disp_Char_x_16(unsigned char t, //设置书写速度(为 1 直接显示,默认为 12)
unsigned char b, //输入 8:8*16 字符,16:16*16 字符
unsigned char LCM12864_page, //LCM12864 的页地址(0~7)
unsigned char LCM12864_col, //LCM12864 的列地址(0~128)注意:右半屏起始是 64
unsigned char const *Char_x_16);
/*------------------延时子程序-----------------------------*/
while(t--);
/*----------------LCM12864 测忙函数 LCM12864_TestBusy()---*/
unsigned char LCM12864_TestBusy(void){
char check;
LCD_DDR=0x00;
LCD_DATA_IN=0xff;
LCD_CLEAR_DI();
LCD_SET_RW();
LCD_CLEAR_E();
LCD_CLEAR_E();
LCD_SET_E();
while(LCD_DATA_IN& LCM12864_STATUS_BUSY);
check=LCD_DATA_IN;
LCD_DDR=0xff;
return(check);
/*------------------写命令到LCD------------------------------*/
LCM12864_TestBusy();
LCD_DDR=0xff;
LCD_DATA_OUT=cmdcode;
LCD_CLEAR_DI();
LCD_CLEAR_RW();
LCD_CLEAR_E();
LCD_CLEAR_E();
LCD_SET_E();
return;
/*-------------------写数据到LCD----------------------------*/
LCD_DDR=0xff;
LCD_DATA_OUT=Dispdata;
LCD_SET_DI();
LCD_CLEAR_RW();
LCD_CLEAR_E();
LCD_CLEAR_E();
LCD_SET_E();
return;
/*-------------------读LCD数据----------------------------*/
unsigned char tmpin;
LCD_DDR=0x00;
LCD_SET_DI();
LCD_SET_RW();
LCD_SET_DI();
LCD_SET_RW();
LCD_CLEAR_E();
LCD_CLEAR_E();
LCD_CLEAR_E();
LCD_CLEAR_E();
LCD_SET_E();
LCD_SET_E();
tmpin=LCD_DATA_IN;
return tmpin;
/*----------------LCM12864 清屏-------------------------*/
void Clear_Screen(void){
LCM12864_Fill_Screen(60,0x00); //写入 0 到每个显示区
/*----------------向 LCM12864 填充数据-------------*/
void LCM12864_Fill_Screen( unsigned char t, //设置涮屏速度(为 1 不涮屏,默认为 60)
unsigned char LCM12864_FillData) //欲写入的数
unsigned char x,y;
LCD_CLEAR_CS1();LCD_CLEAR_CS2(); // 选中左半屏及右半屏
write_data(LCM12864_START_ROW+0); // 设置显示起始行为 0
for(x=0;x<8;x++)
Delay(t); // 涮屏速度延时
write_data(LCM12864_PAGE_START_ADDR+x); // 设置页地址
write_data(LCM12864_COL_START_ADDR); // 设置列地址
for(y=0;y<64;y++)
{write_data(LCM12864_COL_START_ADDR+y);
write_data(LCM12864_FillData);}
LCD_SET_CS1(); // 不选中右半屏
LCD_SET_CS2(); // 不选中右半屏
/*---------------显示 128*64 图片-----------------------*/
void LCM12864_Disp_Bitmap_12864( unsigned char t, //设置涮屏速度(为 1 不涮屏,默认为 60)
unsigned char const *bitmap_12864) //128*64 点阵图像所在数组表
unsigned char j,k;
for(k=0;k<8;k++){ //设置 8 页的显示
Delay(t);
LCD_CLEAR_CS1();LCD_SET_CS2(); //半屏选中
write_data(LCM12864_PAGE_START_ADDR+k); //选中页
write_data(LCM12864_COL_START_ADDR+0); //选中列
for(j=0;j<64;j++){
write_data(bitmap_12864[k*128+j]); //开始写入数据
LCD_SET_CS1();LCD_CLEAR_CS2();
for(j=64;j<128;j++)
/*------------------在 LCM12864 的指定点显示 16*16 点阵汉字---------------*/
unsigned char const *Char_x_16) //16*16 点阵汉字字模(纵向取模,字节倒序
unsigned char j=0,i=0;
if(LCM12864_col < 64 )
LCD_CLEAR_CS1();LCD_SET_CS2(); //判断屏幕使能
LCM12864_col = LCM12864_col - 64;
for(j=0;j<2;j++)
write_data(LCM12864_PAGE_START_ADDR+LCM12864_page+j);
write_data(LCM12864_COL_START_ADDR+LCM12864_col);
for(i=0;i<b;i++)
write_data(Char_x_16[b*j+i]);
Delay(t);
/*------------------初始化LCD屏--------------------------*/
void init_lcd(void)
LCD_DDR|=(1<<LCD_DI)|(1<<LCD_RW)|(1<<LCD_E);
LCD_DDDR=0xff;
LCD_DATA_OUT=0x00;
LCD_CLEAR_RST();
LCD_CLEAR_RST();
LCD_SET_RST();
LCD_SET_RST();
LCD_CLEAR_CS1(); LCD_CLEAR_CS2(); //选中双屏
write_com( Disp_Off); //关显示
write_com(LCM12864_PAGE_START_ADDR+0); //第 0 页位置
write_com(LCM12864_START_ROW+0); //第 0 行
write_com(LCM12864_COL_START_ADDR+0); //第 0 列
write_com(Disp_On);
//write_com(0X06);
//delay(100);
Font.h头文件
/****************液晶显示字库**********************/
/*-- 文字: 欢 --*/
/*-- 宋体 12; 此字体下对应的点阵为:宽 x 高=16x16 --*/
/* 纵向取模,字节倒序 */
unsigned char const huan1[]={ 0x00,0x34,0xC4,0x04,0xC4,0xFC,0x3E,0x24,
0x18,0x0E,0xEF,0xCA,0x48,0x38,0x1C,0x08,
0x00,0x40,0x38,0x0F,0x07,0x3C,0x98,0x60,
0x30,0x1C,0x0F,0x07,0x1C,0x70,0xE0,0x40
/*0x0C,0x6C,0xEC,0x8C,0xFC,0x3C,0x40,0x70,0x3F,0xCF,0xCC,0x0C,0x3C,0x3C,0x00,0x00,
0x10,0x38,0x1C,0x07,0x07,0x4C,0x60,0x30,0x18,0x0F,0x07,0x0C,0x18,0x30,0x20,0x00,*/
/*-- 文字: 迎 --*/
/* 纵向取模,字节倒序 */
unsigned char const ying2[]={
0x60,0x66,0xEE,0xE8,0x00,0xFE,0xFE,0x07,0x03,0xFE,0xFE,0x06,0xFE,0xFE,0x00,0x00,
0x40,0x60,0x3F,0x1F,0x30,0x67,0x67,0x62,0x60,0x6F,0x6F,0x62,0x67,0x67,0x60,0x00
// ASCII 字模的数据表 //
// 码表从 0x20~0x7e //
// 字库:Asc8X16E.dat 纵向取模下高位 //
unsigned char const nAsciiDot[] = // ASCII
0x04,0xFC,0xFC,0x04,0x0C,0xF8,0xF0,0x00, // -D-
0x08,0x0F,0x0F,0x08,0x0C,0x07,0x03,0x00,
0xE0,0xE0,0x00,0x00,0x00,0xE0,0xE0,0x00, // -y-
0x47,0x4F,0x48,0x48,0x68,0x3F,0x1F,0x00,
0x00,0x10,0x18,0xFC,0xFC,0x00,0x00,0x00, // -1-
0x00,0x08,0x08,0x0F,0x0F,0x08,0x08,0x00,
0x08,0x0C,0x84,0xC4,0x64,0x3C,0x18,0x00, // -2-
0x0E,0x0F,0x09,0x08,0x08,0x0C,0x0C,0x00,
0xB8,0xFC,0x44,0x44,0x44,0xFC,0xB8,0x00, // -8-
0x07,0x0F,0x08,0x08,0x08,0x0F,0x07,0x00,
0xF0,0xF8,0x4C,0x44,0x44,0xC0,0x80,0x00, // -6-
0xC0,0xE0,0xB0,0x98,0xFC,0xFC,0x80,0x00, // -4-
0x00,0x00,0x00,0x08,0x0F,0x0F,0x08,0x00,
// Bitmap 点阵数据表 //
// 图片: C:\..鎈 doyleee.bmp,纵向取模下高位,数据排列:从左到右从上到下 //
// 图片尺寸: 128 * 64 //
unsigned char const doyleee[] = // 数据表
0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x01,0x01,0x81,0xF1,0xF1,0xF1,0x71,0x31,
0x31,0x71,0xF1,0xF1,0xE1,0xC1,0x01,0x01,
0x81,0xF1,0xF1,0xF1,0x71,0x01,0x01,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,
0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xF0,0xFF,0xFF,0xFF,0x0F,0x00,0x00,
0x00,0x00,0xC0,0xFF,0xFF,0xFF,0x7F,0x00,
0x00,0xF0,0xFC,0xFE,0xFE,0x0F,0x03,0x03,
0x07,0xFF,0xFE,0xFE,0xF8,0x00,0xE0,0xE0,
0xE0,0xE0,0x00,0x03,0x3F,0xFF,0xFF,0xFC,
0xC0,0xF0,0xFE,0x3F,0x0F,0x03,0x00,0xF0,
0xFF,0xFF,0xFF,0x0F,0x00,0x00,0xF0,0xFC,
0xFE,0xFE,0x3F,0x33,0x33,0x33,0x3F,0x3F,
0x3E,0x38,0x00,0x00,0xF0,0xFC,0xFE,0xFE,
0x3F,0x33,0x33,0x33,0x3F,0x3F,0x3E,0x38,
0x00,0x00,0xF0,0xFC,0xFE,0xFE,0x3F,0x33,
0x33,0x33,0x3F,0x3F,0x3E,0x38,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,
0x8E,0x8F,0x8F,0x8F,0x8C,0x8C,0x8C,0x8C,
0x8E,0x8F,0x87,0x87,0x83,0x81,0x80,0x80,
0x80,0x81,0x87,0x87,0x8F,0x8E,0x8C,0x8C,
0x8F,0x87,0x87,0x83,0x80,0x80,0x80,0xC0,
0xC0,0xC0,0xC0,0xC0,0xC0,0xF3,0x7F,0x3F,
0x0F,0x03,0x00,0x00,0x00,0x00,0x0E,0x0F,
0x0F,0x0F,0x00,0x00,0x00,0x00,0x01,0x07,
0x07,0x0F,0x0E,0x0C,0x0C,0x0F,0x07,0x03,
0x01,0x00,0x00,0x00,0x01,0x07,0x07,0x0F,
0x0E,0x0C,0x0C,0x0F,0x07,0x03,0x01,0x00,
0x00,0x00,0x01,0x07,0x07,0x0F,0x0E,0x0C,
0x0C,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,
0xFF,0x40,0x40,0x40,0x40,0x40,0x40,0x40,
0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,
0x40,0x40,0x40,0x40,0x40,0x00,0x00,0xFC,
0xFC,0x04,0x0C,0xF8,0xF0,0x00,0x00,0xF0,
0xF0,0x00,0x00,0xF0,0xF0,0x00,0x00,0x40,
0x40,0x40,0x40,0x40,0x40,0x00,0x00,0x10,
0x10,0x18,0xFC,0xFC,0x00,0x00,0x00,0x18,
0x1C,0x84,0xC4,0x7C,0x38,0x00,0x00,0xB8,
0xFC,0x64,0xC4,0xFC,0xB8,0x00,0x00,0xE0,
0xF0,0x3C,0x2C,0xE4,0xC0,0x00,0x00,0x80,
0xFC,0x7C,0x00,0xF0,0xF0,0x00,0x00,0xFC,
0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,
0xFC,0x04,0x04,0x1C,0x18,0x00,0x00,0x40,
0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
0x07,0x04,0x06,0x03,0x01,0x00,0x20,0x23,
0x27,0x34,0x1C,0x0F,0x03,0x00,0x00,0x00,
0x00,0x00,0x07,0x07,0x04,0x00,0x00,0x06,
0x07,0x05,0x04,0x04,0x04,0x00,0x00,0x03,
0x07,0x04,0x04,0x07,0x03,0x00,0x00,0x03,
0x07,0x04,0x04,0x07,0x03,0x00,0x00,0x01,
0x01,0x01,0x01,0x07,0x07,0x01,0x00,0x07,
0x07,0x04,0x04,0x04,0x04,0x00,0x00,0x03,
0x07,0x04,0x04,0x07,0x03,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xF0,
0x00,0x00,0x00,0x00,0xF0,0xF0,0x00,0x00,
0x00,0x20,0x20,0xF0,0xF0,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xF0,
0x10,0x10,0x90,0x50,0xF0,0xE0,0x00,0x00,
0xFF,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x81,0x83,
0x86,0x8C,0x8C,0x86,0x83,0x81,0x80,0x80,
0x88,0x88,0x88,0x8F,0x8F,0x88,0x88,0x88,
0x80,0x80,0x8C,0x8C,0x80,0x80,0x87,0x8F,
0x8A,0x89,0x88,0x88,0x8F,0x87,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xFF
点击此处下载 ourdev_484503.pdf(文件大小:1.33M) <font color=green>(原文件名:PG12864LRS-JNN-H_技术手册_完整版.pdf)</font |
