发表于 2009-9-26 16:28:36
http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=3605307&bbs_page_no=1&search_mode=3&search_text=lllll&bbs_id=9999
程序的代码如下:原理图在上面的链接上。
File name : demo_10_3.c
Chip type : ATmega16L
Program type : Application
Clock frequency : 4.000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
#include <mega16.h>
flash unsigned char led_7[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
flash unsigned char position[6]={0xfe,0xfd,0xfb,0xf7};
unsigned char dis_buff[4]={0,0,0,0},posit;
bit time_2ms_ok;
// ADC电压值送显示缓冲区函数
void adc_to_disbuffer(unsigned int adc)
unsigned char i;
for (i=0;i<=3;i++)
dis_buff=adc%10;
adc /= 10;
// Timer 0 比较匹配中断服务
interrupt [TIM0_COMP] void timer0_comp_isr(void)
time_2ms_ok = 1;
// ADC 转换完成中断服务
interrupt [ADC_INT] void adc_isr(void)
unsigned int adc_data,adc_v;
adc_data=ADCW; //读取ADC置换结果
adc_v=(unsigned long)adc_data*5000/1024; //换算成电压值
adc_to_disbuffer(adc_v);
void display(void) // 4位LED数码管动态扫描函数
PORTA |= 0x0f;
PORTC = led_7[dis_buff[posit]];
if (posit==3) PORTC |= 0x80;
PORTA &= position[posit];
if (++posit >=4 ) posit = 0;
DDRA=0x0f;
PORTA=0x0f;
DDRC=0xff; // LED显示控制I/O端口初始化
PORTC=0x00;
// T/C0 初始化
TCCR0=0x0B; // 内部时钟,64分频(4M/64=62.5KHz),CTC模式
TCNT0=0x00;
OCR0=0x7C; // OCR0 = 0x7C(124),(124+1)/62.5=2ms
TIMSK=0x02; // 允许T/C0比较中断
// ADC 初始化
ADMUX=0x47; // 参考电源AVcc、ADC7单端输入
SFIOR&=0x1F;
SFIOR|=0x60; // 选择T/C0比较匹配中断为ADC触发源
ADCSRA=0xAD; // ADC允许、自动触发转换、ADC转换中断允许、ADCclk=125Kz
#asm("sei") // 开放全局中断
while (1)
if (time_2ms_ok)
display(); // LED扫描显示
time_2ms_ok = 0;
