RT,在NS网站上找到的,传上来方便下载。
点击此处下载 ourdev_491847.rar(文件大小:40.88M) (原文件名:AN.rar)
内容如下:
AN-A: The Monolithic Operational Amplifier: A Tutorial Study
AN-20: An Application Guide for Op Amps
AN-31: Op Amp Circuit Collection
AN-4: Monolithic Op Amp-The Universal Linear Component
AN-116: Use the LM158/LM258/LM358 Dual, Single Supply Op Amp
LB-26: Specifying Selected Op Amps and Comparators
LB-19: Predicting Op Amp Slew Rate Limited Response
AN-104: Noise Specs Confusing?
LB-22: Low Drift Amplifiers
OA-30: Current vs. Voltage Feedback Amplifiers
AN-241: Working with High Impedance Op Amps
AN-242: Applying a New Precision Op Amp
TP-15: Reducing DC Errors in Op Amps (Addendum to AN241 & 242)
LB-44: Get More Power Out of Dual or Quad Op-Amps
AN-272: Op Amp Booster Designs
AN-447: Protection Schemes for BI-FET Amplifiers and Switches
AN-24: A Simplified Test Set for Op Amp Characterization
AN-227: Applications of Wide-Band Buffer Amplifiers
AN-262: Applying Dual and Quad FET Op Amps
AN-298: Isolation Techniques for Signal Conditioning
AN-775: Specifications and Architectures of Sample-and-Hold Amplifiers
LB-2: Feedforward Compensation Speeds Op Amp
LB-4: Fast Compensation Extends Power Bandwidth
LB-42: Get Fast Stable Response From Improved Unity-Gain Followers
OA-11: A Tutorial on Applying Op Amps to RF Applications
OA-14: Improving Amplifier Noise Figure for High 3rd Intercept Amplifiers
OA-21: Component Pre-distortion for Sallen Key Filters
OA-22: Pushing Low Quiescent Power Op Amps to Greater than 55dBM 2-Tone Intercept
OA-24: Measuring And Improving Differential Gain and Differential Phase For Video Buffers w/Disable
OA-26: Designing High Speed Active Filters
OA-27: Low-Sensitivity, Lowpass Filter Design
OA-28: Low-Sensitivity, Bypass Filter Design with Turning Method
OA-29: Low-Sensitivity, Bypass Filter Design with Parasitic Compensation
AN-1112: Micro SMD Wafer Level Chip Scale Package
AN-1187: Leadless Leadframe Package
AN-1201: 8-Lead LLP Thermal Performance and Design Guideleines
AB-107: Reworking the LLP Chip Scale Package
AN-29: IC Op Amp Beats FETs on Input Current
AN-71: Micropower Circuits Using the LM4250 Programmable Op Amp
AN-72: The LM3900: A New Current-Differencing Quad of Plus or Minus Input Amplifiers
AN-211: New Op Amp Ideas
TP-14: Low Voltage Techniques (Addendum to AN 211)
AN-222: Application Note 222 Super Matched Bipolar Transistor Pair Sets New Standards for Drift and Noise
AN-346: High-Performance Audio Applications of the LM833
AN-480: A 40 MHz Programmable Video Op Amp
AN-549: LM6361/LM6364/LM6365 Fast Op Amps Offer High Speed at Low Power Consumption
LB-17: LM118 Op Amp Slews 70V/microsecond
OA-12: Noise Analysis for High Speed Op Amps
OA-23: CLC522 Advanced Operating Considerations and Military Specifications
OA-16: Wideband AGC Amplifier as a Differential Amplifier
OA-31: Current-Feedback Amplifiers
AN-597: Current Feedback Amplifier
AN-278: Designing with a New Super Fast Dual Norton Amplifier
AN-813: Topics on Using the LM6181-A New Current Feedback Amplifier
OA-07: Current- Feedback Op Amp Applications Circuit Guide
OA-13: Current- Feedback Loop Gain Analysis
OA-15: Frequent Faux Pas in Applying Wideband Current Feedback Amplifiers
OA-20: Current Feedback Myths Debunked
OA-25: Stability Analysis of Current Feedback Amplifiers
AB-104: Photo-Diode Current-To-Voltage Converters
AB-108: Unlimited Capacitive Load rive Op Amp Takes Guesswork Out Of Design
AB-116: Lower System Cost Solution for Transmitting Video
AN-30: Log Converters
AN-256: Circuitry for Inexpensive Relative Humidity Measurement
AN-263: Sine Wave Generation Techniques
AN-265: An Electronic Watt-Watt-Hour Meter
AN-266: Circuit Applications of Sample-Hold Amplifiers
AN-285: An Acoustic Transformer Powered Super-High Isolation Amplifier
AN-294: Special Sample and Hold Techniques
AN-295: A High Performance Industrial Weighing System
AN-299: Application Note 299 Audio Applications of Linear Integrated Circuits
AN-300: Simple Circuit Detects Loss of 4-20 mA Signal
AN-311: Application Note 311 Theory and Applications of Logarithmic Amplifiers
AN-779: A Basic Introduction to Filters - Active, Passive and Switched-Capacitor
AN-1240: Video Transmission over Twisted Pair Wire
AN-1516: Pspice Universal Test Circuits
LB-1: Instrumentation Amplifier
LB-5: High Q Notch Filter
LB-16: Easily Tuned Sine Wave Oscillators
LB-21: Instrumentational Amplifiers
LB-23: Precise Tri-Wave Generation
LB-25: True rms Detector
LB-52: A Low-Noise Precision Op Amp
AN-74: LM139/LM239/LM339 A Quad of Independently Functioning Comparators
AN-41: Precision IC Comparator Runs from Plus 5V Logic Supply
AN-87: Comparing the High Speed Comparators
AN-286: Applications of the LM392 Comparator Op Amp IC
LB-6: Fast Voltage Comparators with Low Input Current
LB-39: Circuit Techniques for Avoiding Oscillations in Comparator Applications
AN-253: LH0024 and LH0032 High Speed Op Amp Applications
AN-79: IC Preamplifier Challenges Choppers on Drift
AN-261: Low Distortion Wideband Power Op Amp
LB-11: The LM110 - An Improved IC Voltage Follower
LB-20: A Fully Differential Input Voltage Amplifier
LB-24: Versatile IC PreAmplifier Makes Thermocouple Amplifier with Cold Junction Compensation
LB-27: Micropower Thermometer
LB-32: MicroVolt Comparator
OA-19: CLC505 Op Amp Capable of MicroPower Operation |
