发表于 2009-11-16 18:01:43
ID 型号 厂家 用途 构造 沟道 方式 v111(V) 区分 ixing(A) pdpch(W) waixing
11 2SJ39 三菱 LF A J P D 50 GDO -10m .15/CH 4-81
4863 μPA60A NEC Diff J N D -40 GDO 50m .25/CH 4-111
4864 μPA61A NEC Diff J N D -40 GDO 50m .25/CH 4-111
4866 μPA63H NEC LF A J N D -60 GDO 10m .25/CH 4-66
4867 μPA68H NEC LF LN A J N D -50 GDO 10m .25/CH 4-66
4860 μPA33A NEC DC, Chop MOS P -30 DSS -20m 0.1/CH 4-22
302 2SJ399 日立 HS PSW MOS P E -30 DSS -0.2 0.15 4-185B
1914 2SK1958 NEC HS SW, 低电压用 MOS N E 16 DSS ±0.1 0.15 4-246C
2018 2SK2090 NEC MOS N E 50 DSS ±0.1 0.15 4-255C
2203 2SK2373 日立 HS PSW MOS N E 30 DSS 0.2 0.15 4-185B
1817 2SK1824 NEC MOS N E 30 DSS ±0.1 0.2 4-356
2069 2SK2158 NEC MOS N E 50 DSS ±0.1 0.2 4-275A
46 2SJ90 东芝 LF LN A J P D 30 GDS -10m 0.2/CH 4-75
392 2SK111 三菱 LF LN A J N D -30 GDO 10m 0.2/CH 4-84
426 2SK150 东芝 LF LN A J N D -50 GDS 10m 0.2/CH 4-75
443 2SK171 三菱 LF LN A J N D -20 GDO 10m 0.2/CH 4-84
556 2SK332 三洋 Diff J N D -40 GDS 10m 0.2/CH 4-107
557 2SK333 三洋 Diff J N D -80 GDS 10m 0.2/CH 4-107
4862 μPA50A NEC LF A J N D -60 GDO 10m 0.2/CH 4-44
4875 μPA602T NEC MOS N E 50 DSS 0.1 0.3 4-355B
4876 μPA603T NEC MOS P E -50 DSS -0.1 0.3 4-355B
505 2SK270 东芝 LF LN A J N D -40 GDS 10m 0.3/CH 4-75
32 2SJ75 东芝 LF LN A J P D 25 GDS -10m 0.4/CH 4-99
463 2SK194 NEC LF LN A J N D -40 GDO 10m 0.4/CH 4-109
492 2SK240 东芝 LF LN A J N D -40 GDS 10m 0.4/CH 4-110
185 2SJ238 东芝 SW, DDC, Motor-D MOS P E -60 DSS -1 0.5 4-256
2266 IRCP054 IR N 60 70 0.5 TO-247AC
30 2SJ73 东芝 LF LN A J P D 25 GDS -10m 0.6/CH 4-98
422 2SK146 东芝 LF LN A J N D -40 GDS 10m 0.6/CH 4-85
125 2SJ178 NEC HS SW MOS P E -30 DSS ±1 0.75 4-53C
143 2SJ196 NEC SW MOS P E -60 DSS ±1 0.75 4-53C
145 2SJ198 NEC SW MOS P E -100 DSS ±0.5 0.75 4-53D
1306 2SK1272 NEC HS SW MOS N E 60 DSS ±1 0.75 4-53C
1510 2SK1482 NEC SW, Motor-D MOS N E 30 DSS ±1.5 0.75 4-53C
1512 2SK1484 NEC SW, DDC MOS N E 100 DSS ±0.5 0.75 4-53D
297 2SJ386 日立 HS PSW MOS P E -30 DSS -3 0.9 4-97B
2015 2SK2085 日立 HS PSW MOS N E 100 DSS 1 0.9 4-97B
127 2SJ180 NEC HS SW MOS P E -30 DSS ±1 1 4-217
133 2SJ186 日立 SW-Reg, DDC MOS P E -200 DSS -0.5 1 4-295
172 2SJ225 三洋 HS SW MOS P E -30 DSS -1 1 4-348
175 2SJ228 三洋 HS SW MOS P E -60 DSS -0.8 1 4-348
178 2SJ231 三洋 HS SW MOS P E -100 DSS -0.5 1 4-348
190 2SJ244 日立 HS PSW, DDC MOS P E -12 DSS ±2 1 4-295
214 2SJ278 日立 HS PSW, DDC MOS P E -60 DSS -1 1 4-295
244 2SJ317 日立 SW, PA MOS P E -12 DSS ±2 1 4-295
268 2SJ353 NEC MOS P E -60 DSS ±1.5 1 4-217
275 2SJ361 日立 HS PSW MOS P E -20 DSS -2 1 4-295
276 2SJ363 日立 HS PSW MOS P E -30 DSS -2 1 4-295
459 2SK191 日立 LF LN A J N D -15 DGO 10m 1 4-97A
514 2SK279 三菱 S~X-Band PA GaAs N D 8 DSX 250m 1 4-122
751 2SK601 松下 SW MOS N E 80 DS 500m 1 4-189
764 2SK615 松下 SW MOS N E 80 DS 500m 1 4-195
768 2SK619 日立 MOS N E 70 DSS 300m 1 4-136B
828 2SK680 NEC SW MOS N E 30 DSS ±1 1 4-216A
830 2SK681 NEC SW MOS N E 30 DSS ±1 1 4-217
831 2SK681A NEC HS SW, Motor-D MOS N E 30 DSS ±1 1 4-217
840 2SK690 松下 UHF PA GaAs/MES N D 10 DS 500m 1 4-189
1308 2SK1274 NEC HS SW MOS N E 60 DSS ±1.5 1 4-217
1372 2SK1334 日立 SW-Reg, DDC MOS N E 200 DSS 1 1 4-295
1609 2SK1579 日立 HS PSW, D MOS N E 12 DSS 2 1 4-295
1718 2SK1697 日立 HS PSW MOS N E 60 DSS 0.5 1 4-295
1719 2SK1698 日立 HS PSW, DDC MOS N E 100 DSS 0.3 1 4-295
1743 2SK1725 三洋 HS SW MOS N E 30 DSS 1 1 4-348
1745 2SK1727 三洋 HS SW MOS N E 60 DSS 0.8 1 4-348
1748 2SK1730 三洋 HS SW MOS N E 30 DSS 1.8 1 4-348
1751 2SK1733 三洋 HS SW MOS N E 60 DSS 1.5 1 4-348
1754 2SK1736 三洋 HS SW MOS N E 100 DSS 1 1 4-348
1762 2SK1748, 1748-Z NEC SW, Motor-D MOS N E 60 DSS ±8 1 4-276/Z:277
1776 2SK1764 日立 HS PSW MOS N E 60 DSS 2 1 4-295
1782 2SK1772 日立 HS PSW, DDC MOS N E 30 DSS 1 1 4-295
2001 2SK2070 NEC SW, DDC MOS N E 100 DSS ±1.5 1 4-367
2077 2SK2169 三洋 HS SW MOS N E 250 DSS 0.4 1 4-348
2133 2SK2247 日立 HS PSW MOS N E 30 DSS ±2 1 4-295
2167 2SK2315 日立 HS PSW MOS N E 60 DSS ±2 1 4-295
2228 IRC540 IR N 100 29 1 TO-204AA
2234 IRC640 IR N 200 18 1 TO-204AA
2236 IRC644 IR N 250 14 1 TO-204AA
2240 IRC740 IR N 400 10 1 TO-204AA
2246 IRC840 IR N 500 8 1 TO-204AA
2272 IRCZ44 IR N 60 50 1 TO-204AA
2578 IRFD1Z0 IR N 100 0.5 1 P-DIP4PIN
2579 IRFD1Z3 IR N 60 0.4 1 P-DIP4PIN
2580 IRFD010 IR N 50 1.7 1 P-DIP4PIN
2581 IRFD012 IR N 50 1.4 1 P-DIP4PIN
2583 IRFD020 IR N 50 2.4 1 P-DIP4PIN
2584 IRFD022 IR N 50 2.2 1 P-DIP4PIN
2586 IRFD110 IR N 100 1.0 1 P-DIP4PIN
2587 IRFD113 IR N 60 0.8 1 P-DIP4PIN
2588 IRFD120 IR N 100 1.3 1 P-DIP4PIN
2589 IRFD123 IR N 60 1.1 1 P-DIP4PIN
2590 IRFD210 IR N 200 0.6 1 P-DIP4PIN
2591 IRFD213 IR N 150 0.45 1 P-DIP4PIN
2592 IRFD220 IR N 200 0.8 1 P-DIP4PIN
2593 IRFD223 IR N 150 0.7 1 P-DIP4PIN
2594 IRFD9010 IR P -50 -1.1 1 P-DIP4PIN
2595 IRFD9012 IR P -50 -0.91 1 P-DIP4PIN
2597 IRFD9020 IR P -50 -1.6 1 P-DIP4PIN
2598 IRFD9022 IR P -50 -1.4 1 P-DIP4PIN
2600 IRFD9110 IR P -100 -0.7 1 P-DIP4PIN
2601 IRFD9113 IR P -60 -0.6 1 P-DIP4PIN
2602 IRFD9120 IR P -100 -1.0 1 P-DIP4PIN
2603 IRFD9123 IR P -150 -0.8 1 P-DIP4PIN
2604 IRFD9210 IR P -200 -0.4 1 P-DIP4PIN
2605 IRFD9213 IR P -150 -0.3 1 P-DIP4PIN
2606 IRFD9220 IR P -200 -0.6 1 P-DIP4PIN
2607 IRFD9223 IR P -150 -0.45 1 P-DIP4PIN
3004 IRLD014 IR N 60 1.7 1 HD-1
3005 IRLD024 IR N 60 2.5 1 HD-1
3006 IRLD110 IR N 100 1 1 HD-1
3007 IRLD120 IR N 100 1.3 1 HD-1
3126 IRFD1Z0 MOT N 100 0.5 1 CASE370-01
3127 IRFD1Z3 MOT N 60 0.4 1 CASE370-01
3128 IRFD110 MOT N 100 1 1 CASE370-01
3129 IRFD113 MOT N 60 0.8 1 CASE370-01
3130 IRFD120 MOT N 100 1.3 1 CASE370-01
3131 IRFD121 MOT N 60 1.3 1 CASE370-01
3132 IRFD122 MOT N 100 1.1 1 CASE370-01
3133 IRFD123 MOT N 60 1.1 1 CASE370-01
3134 IRFD210 MOT N 200 0.6 1 CASE370-01
3135 IRFD211 MOT N 150 0.6 1 CASE370-01
3136 IRFD212 MOT N 200 0.45 1 CASE370-01
3137 IRFD213 MOT N 150 0.45 1 CASE370-01
3138 IRFD220 MOT N 200 0.8 1 CASE370-01
3139 IRFD221 MOT N 150 0.8 1 CASE370-01
3140 IRFD222 MOT N 200 0.7 1 CASE370-01
3141 IRFD223 MOT N 150 0.7 1 CASE370-01
3846 IRFD020 SILICONIX N 50 2.4 1 4-Pin DIP
3847 IRFD120 SILICONIX N 100 1.3 1 P-DIP4P
3848 IRFD123 SILICONIX N 60 1.1 1 P-DIP4P
3849 IRFD9020 SILICONIX P -50 -1.6 1 4-Pin DIP
3850 IRFD9120 SILICONIX P -100 -1.0 1 P-DIP4P
3851 IRFD9123 SILICONIX P -60 -0.8 1 P-DIP4P
4239 FLR014FH 富士通 K-Band PA GaAs N D 15 DS 1 4-223
4401 FSX51WF 富士通 X-Band PA GaAs N D 12 DS 1 4-130
4402 FSX51X 富士通 X-Band PA GaAs N D 12 DS 1
4582 MGF1601 三菱 MW PA GaAs N D -8 GDO 250m 1
4895 μPA1600CX/GS NEC D MOS N 30 O 0.5/CH 1 4-353/354
4896 μPA1601CX/GS NEC D MOS N 50 O 0.5/CH 1 4-353/354
4897 μPA1602CX/GS NEC D MOS N 50 O 0.5/CH 1 4-353/354
4898 μPA1603CX NEC Motor-D MOS N 50 O 1.5/CH 1 4-316
4899 μPA1604CX NEC Motor-D MOS N 50 O 1.5/CH 1 4-316
4900 μPA1640GS NEC MOS 30 O 0.1/CH 1 4-354
4901 μPD16803GS NEC Motor-D MOS N 15 M ±1 1 4-318
2676 IRFG1Z0 IR N 100 0.40* 1.0* 2SK×4
2677 IRFG1Z3 IR N 60 0.35* 1.0* 2SK×4
4150 FLK012WF 富士通 Ku-Band PA GaAs N D 15 DS 1.15 4-130
4151 FLK012XP 富士通 Ku-Band, PA GaAs N D 15 DS 1.15
4240 FLR014XP 富士通 K-Band PA GaAs N D 15 DS 1.15
4241 FLR016FH 富士通 K-Band PA GaAs N D 15 DS 1.15 4-223
273 2SJ359 东芝 HS SW, DDC MOS P E -60 DSS -5 1.2 4-387
290 2SJ378 东芝 HS SW, DDC MOS P E -60 DSS -5 1.2 4-387
2104 2SK2200 东芝 HS SW, DDC MOS N E 100 DSS 3 1.2 4-378
2123 2SK2228 东芝 HS SW, DDC MOS N E 60 DSS 5 1.2 4-387
2124 2SK2229 东芝 HS SW, DDC MOS N E 60 DSS 5 1.2 4-387
2125 2SK2230 东芝 HS SW, DDC MOS N E 250 DSS 2 1.2 4-387
4583 MGF1801 三菱 S~X-Band PA GaAs N D -8 GDO 250m 1.2 4-167
4243 FLR024FH 富士通 K-Band PA GaAs N D 15 DS 1.25 4-223
469 2SK201 NEC C~X-Band A/OSC GaAs N D 10 DSX 400m 1.3 4-120
2582 IRFD014 IR N 60 1.7 1.3 HD-1
2585 IRFD024 IR N 60 2.5 1.3 HD-1
2596 IRFD9014 IR P -60 -1.1 1.3 HD-1
2599 IRFD9024 IR P -60 -1.6 1.3 HD-1
974 2SK839 松下 MOS N 40 DSS 2 1.4
975 2SK840 松下 MOS N 40 DSS 2 1.4
976 2SK841 松下 MOS N 250 DSS 1 1.4
977 2SK842 松下 MOS N 400 DSS 500m 1.4
2679 IRFG113 IR N 60 0.85* 1.4* 2SK×4
2680 IRFG6110 IR * ±100 +0.95* 1.4* 2SK×2+2SJ×2
2681 IRFG6113 IR * ±60 +0.85* 1.4* 2SK×2+2SJ×2
2682 IRFG9110 IR P -100 -0.75* 1.4* 2SJ×4
2683 IRFG9113 IR P -60 -0.65* 1.4* 2SJ×4
2678 IRFG110 IR N 100 0.95* 1.4/U 2SK×4
173 2SJ226 三洋 HS SW MOS P E -30 DSS -2 1.5 4-347
174 2SJ227 三洋 HS SW MOS P E -30 DSS -3 1.5 4-347
176 2SJ229 三洋 HS SW MOS P E -60 DSS -1.6 1.5 4-347
177 2SJ230 三洋 HS SW MOS P E -60 DSS -2.5 1.5 4-347
179 2SJ232 三洋 HS SW MOS P E -100 DSS -2.5 1.5 4-347
180 2SJ233 三洋 HS SW MOS P E -100 DSS -2.5 1.5 4-347
274 2SJ360 东芝 HS SW, DDC MOS P E -60 DSS -1 1.5 4-256
1735 2SK1717 东芝 Motor-D, DDC MOS N E 60 DSS 2 1.5 4-256
1749 2SK1731 三洋 HS SW MOS N E 30 DSS 3 1.5 4-347
1750 2SK1732 三洋 HS SW MOS N E 30 DSS 4.5 1.5 4-347
1752 2SK1734 三洋 HS SW MOS N E 60 DSS 2.5 1.5 4-347
1753 2SK1735 三洋 HS SW MOS N E 60 DSS 4 1.5 4-347
1755 2SK1737 三洋 HS SW MOS N E 100 DSS 1.8 1.5 4-347
1756 2SK1738 三洋 HS SW MOS N E 100 DSS 3 1.5 4-347
4251 FLS02W 富士通 S-Band PA GaAs/SB N D 12 DS 1.5 4-93
4403 FSX52WF 富士通 X-Band PA GaAs N D 12 DS 1.5 4-130
4404 FSX52X 富士通 X-Band PA GaAs N D 12 DS 1.5
4598 MGF2407 三菱 MW PA GaAs N D -15 GDO 250m 1.5
4599 MGF2407A 三菱 MW PA GaAs N D -15 GDO 250m 1.5
2224 IRC530 IR N 100 14 1.7 TO-204AA
2230 IRC630 IR N 200 9 1.7 TO-204AA
2232 IRC634 IR N 250 8.1 1.7 TO-204AA
2238 IRC730 IR N 400 5.5 1.7 TO-204AA
2242 IRC830 IR N 500 4.5 1.7 TO-204AA
2270 IRCZ34 IR N 60 30 1.7 TO-204AA
1834 2SK1850 NEC SW, Motor-D MOS N E 60 DSS ±10 1.8 4-365
1835 2SK1851 NEC SW, Motor-D MOS N E 60 DSS ±15 1.8 4-365
1836 2SK1852 NEC SW, Motor-D MOS N E 100 DSS ±10 1.8 4-365
1837 2SK1853 NEC SW, Motor-D MOS N E 100 DSS ±15 1.8 4-365
2050 2SK2132 NEC SW, SW-Reg, DDC MOS N E 180 DSS ±4 1.8 4-365
4584 MGF1802 三菱 C~X-Band PA GaAs N D -8 GDO 250m 1.8 4-170
4152 FLK022WG 富士通 Ku-Band, PA GaAs N D 15 DS 1.875 4-202
4153 FLK022XP/XV 富士通 Ku-Band, PA GaAs N D 15 DS 1.88
4244 FLR024XP/XV 富士通 K-Band PA GaAs N D 15 DS 1.88
4245 FLR026FH 富士通 K-Band PA GaAs N D 15 DS 1.88 4-223 |
