发表于 2009-12-9 00:33:24
Data Types Previous Top Next
The following table lists all the data types supported by the CodeVisionAVR C compiler, their range of possible values and their size:
Type Size(Bits) Range
bit 1 0 , 1
bool, _Bool 8 0 , 1
char 8 -128 to 127
unsigned char 8 0 to 255
signed char 8 -128 to 127
int 16 -32768 to 32767
short int 16 -32768 to 32767
unsigned int 16 0 to 65535
signed int 16 -32768 to 32767
long int 32 -2147483648 to 2147483647
unsigned long int 32 0 to 4294967295
signed long int 32 -2147483648 to 2147483647
float 32 ±1.175e-38 to ±3.402e38
double 32 ±1.175e-38 to ±3.402e38
The bit data type is not allowed as the type of an array element or structure/union member.
If the Project|Configure|C Compiler|Code Generation|char is unsigned option is checked or #pragma uchar+ is used, then char has by default the range 0..255.
二楼的没有bool布尔变量类型? 我这个资料怎么会有布尔型呢? 我的是CVAVR 2.04.4a版本,以前在老版本里还真没用过bool型,这次想用一下,发现问题哦。
(不会贴图,复制了一下,不是表格了 :) |
