发表于 2010-1-15 15:31:56
Response syntax: +CREG: <mode>, <stat> [ ,<lac>,<ci> ] for AT+CREG?
Command only
6.3.3 Defined values
<mode>
0: Disable network registration unsolicited result code (default)
1: Enable network registration unsolicited result code +CREG: <stat>, when
there is a network registration status change.
2: Enable network registration and location information unsolicited result code
+CREG: <stat>,<lac>,<ci> if there is a change of network cell.
<stat>
0: not registered, ME is not currently searching for a new operator.
1: registered, home network.
2: not registered, ME currently searching for a new operator to register to.
3: registration denied.
4: unknown.
5: registered, roaming.
<lac>: string type; two byte location area code in hexadecimal format (e.g. "00C3"
equals 195 in decimal).
<ci>: string type; two byte cell ID in hexadecimal format. |
