现在我的空闲钩子函数设置是
extern void EnterSTOPMode_RTCAlarm(void);
void rt_thread_idle_sethook(void EnterSTOPMode_RTCAlarm(void))
rt_thread_idle_hook=EnterSTOPMode_RTCAlarm;
下面是具体实现
#include "stm32f10x.h"
#include "stm32_eval.h"
extern void RTC_Configuration(void);
ErrorStatus HSEStartUpStatus;
* @brief Configures system clock after wake-up from STOP: enable HSE, PLL
* and select PLL as system clock source.
* @param None
* @retval None
void SYSCLKConfig_STOP(void)
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
#ifdef STM32F10X_CL
/* Enable PLL2 */
RCC_PLL2Cmd(ENABLE);
/* Wait till PLL2 is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLL2RDY) == RESET)
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
* @brief Configures EXTI Lines.
* @param None
* @retval None
void EXTI_Configuration(void)
EXTI_InitTypeDef EXTI_InitStructure;
/* Configure EXTI Line17(RTC Alarm) to generate an interrupt on rising edge */
EXTI_ClearITPendingBit(EXTI_Line17);
EXTI_InitStructure.EXTI_Line = EXTI_Line17;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
* @brief Configures NVIC and Vector Table base location.
* @param None
* @retval None
static void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* 2 bits for Preemption Priority and 2 bits for Sub Priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = RTCAlarm_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* Initialize LEDs and Key Button mounted on STM3210X-EVAL board */
STM_EVAL_LEDInit(LED1);
STM_EVAL_LEDInit(LED2);
STM_EVAL_LEDInit(LED3);
STM_EVAL_PBInit(Button_KEY, Mode_EXTI);
/* Configure EXTI Line to generate an interrupt on falling edge */
EXTI_Configuration();
/* Configure RTC clock source and prescaler */
RTC_Configuration();
/* NVIC configuration */
NVIC_Configuration();
/* Turn on LED1 */
STM_EVAL_LEDOn(LED1);
while (1)
/* Wait till RTC Second event occurs */
RTC_ClearFlag(RTC_FLAG_SEC);
while(RTC_GetFlagStatus(RTC_FLAG_SEC) == RESET);
/* Alarm in 1 second */
RTC_SetAlarm(RTC_GetCounter()+ 1);
/* Wait until last write operation on RTC registers has finished */
RTC_WaitForLastTask();
/* Turn off LED1 */
STM_EVAL_LEDOff(LED1);
//rt_kprintf("Enter stop mode...\n");
/* Request to enter STOP mode with regulator in low power mode*/
PWR_EnterSTOPMode(PWR_Regulator_LowPower, PWR_STOPEntry_WFI);
/* At this stage the system has resumed from STOP mode -------------------*/
/* Turn on LED1 */
//rt_kprintf("Wake from stop mode\n");
/* Configures system clock after wake-up from STOP: enable HSE, PLL and select
PLL as system clock source (HSE and PLL are disabled in STOP mode) */
SYSCLKConfig_STOP();
其中RTC的配置是
/* Enable PWR and BKP clocks */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);
/* Allow access to BKP Domain */
PWR_BackupAccessCmd(ENABLE);
/* Reset Backup Domain */
BKP_DeInit();
/* Enable LSE */
RCC_LSEConfig(RCC_LSE_ON);
/* Wait till LSE is ready */
while (RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
/* Select LSE as RTC Clock Source */
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
/* Enable RTC Clock */
RCC_RTCCLKCmd(ENABLE);
/* Wait for RTC registers synchronization */
RTC_WaitForSynchro();
/* Set RTC prescaler: set RTC period to 1sec */
RTC_SetPrescaler(32767); /* RTC period = RTCCLK/RTC_PR = (32.768 KHz)/(32767+1) */
但是我把程序下载进去后,低功耗程序根本没有执行,请大家分析哈原因,谢谢!困惑中 |
