发表于 2010-3-23 08:19:14
附录:
1、通用数据总线测试程序:
/* Set the data bus width to 32 bits. */
typedef uint32_t datum;
* Function: memtestDataBus
* Description: Test the data bus wiring in a memory region by
* performing a walking 1's test at a fixed address
* within that region. The address (and hence the
* memory region) is selected by the caller.
* Notes:
* Returns: 0 if the test fails. The failure address is returned
* in the parameter ppFailAddr.
* 1 if the test succeeds. The parameter ppFailAddr is
* set to NULL.
int memtestDataBus(datum *pAddress, datum **ppFailAddr)
datum pattern;
*ppFailAddr = NULL;
/* Perform a walking 1's test at the given address. */
for (pattern = 1; pattern != 0; pattern <<= 1)
/* Write the test pattern. */
*pAddress = pattern;
/* Read it back (immediately is okay for this test). */
if (*pAddress != pattern)
*ppFailAddr = pAddress;
return 0;
return 1;
2、通用地址总线测试程序
* Function: memtestAddressBus
* Description: Test the address bus wiring in a memory region by
* performing a walking 1's test on the relevant bits
* of the address and checking for aliasing. The test
* will find single-bit address failures such as stuck
* high, stuck low, and shorted pins. The base address
* and size of the region are selected by the caller.
* Notes: For best results, the selected base address should
* have enough LSB 0's to guarantee single address bit
* changes. For example, to test a 64 KB region, select
* a base address on a 64 KB boundary. Also, the number
* of bytes must describe a power-of-two region size.
* set to NULL.
int memtestAddressBus(datum *pBaseAddress, uint32_t numBytes, datum **ppFailAddr)
uint32_t addressMask = (numBytes - 1);
uint32_t offset;
uint32_t testOffset;
datum pattern = (datum) 0xAAAAAAAA;
datum antipattern = (datum) ~pattern;
*ppFailAddr = NULL;
/* Write the default pattern at each of the power-of-two offsets. */
for (offset = sizeof(datum); (offset & addressMask) != 0; offset <<= 1)
pBaseAddress[offset] = pattern;
/* Check for address bits stuck high. */
pBaseAddress[0] = antipattern;
for (offset = sizeof(datum); offset & addressMask; offset <<= 1)
if (pBaseAddress[offset] != pattern)
*ppFailAddr = &pBaseAddress[offset];
return 0;
pBaseAddress[0] = pattern;
/* Check for address bits stuck low or shorted. */
for (testOffset = sizeof(datum); testOffset & addressMask; testOffset <<= 1)
pBaseAddress[testOffset] = antipattern;
if ((pBaseAddress[offset] != pattern) && (offset != testOffset))
return 0;
pBaseAddress[testOffset] = pattern;
return 1;
