发表于 2010-4-1 10:41:35
回复【6楼】kunnsd 魏坤
请问魏坤:现在我的示波器按你给的步骤在Flash programer环境下载后提示信息为以下内容。我的下载线系ByteBlasterII [LPT1]
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd D:/HANDHELD_DSO_PROJECT_V2.0/software/new_handheld_dso/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="D:/HANDHELD_DSO_PROJECT_V2.0/OLD
1.sof" --output="OLD1.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=OLD1.
opt D:/HANDHELD_DSO_PROJECT_V2.0/OLD1.sof OLD1.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 68 megabytes
Info: Processing ended: Tue Mar 31 11:17:52 2009
Info: Elapsed time: 00:00:04
Info: Total CPU time (on all processors): 00:00:03
Info: Command: quartus_cpf --no_banner --convert OLD1.pof OLD1.rpd
Info: Peak virtual memory: 65 megabytes
Info: Processing ended: Tue Mar 31 11:17:56 2009
Info: Total CPU time (on all processors): 00:00:04
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01001800 "OLD1.fla
sh"
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
: Checksumming existing contents
00000000 : Verifying existing contents
00010000 : Verifying existing contents
00000000 : Reading existing contents
00010000 : Reading existing contents
Checksummed/read 7kB in 0.3s
00000000 ( 0%): Erasing
00010000 (50%): Erasing
Erased 128kB in 1.2s (106.6kB/s)
00000000 ( 0%): Programming
00010000 (50%): Programming
Programmed 122KB +6KB in 5.1s (25.0KB/s)
Did not attempt to verify device contents
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="OLD1.flash" --input="new_handhel
d_dso.elf" --output="epcs_controller.flash"
# Programming flash with the project
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01001800 "epcs_con
troller.flash"
00020000 : Verifying existing contents
00030000 : Verifying existing contents
00040000 : Verifying existing contents
00050000 : Verifying existing contents
00020000 : Reading existing contents
00030000 : Reading existing contents
00040000 : Reading existing contents
00050000 : Reading existing contents
Checksummed/read 65kB in 3.0s
00010000 ( 0%): Erasing
00020000 (20%): Erasing
00030000 (40%): Erasing
00040000 (60%): Erasing
00050000 (80%): Erasing
Erased 320kB in 3.1s (103.2kB/s)
00010000 ( 0%): Programming
00020000 (20%): Programming
00030000 (40%): Programming
00040000 (60%): Programming
00050000 (80%): Programming
Programmed 256KB +64KB in 10.6s (30.1KB/s)
提示无验正内容,关电源开机还是白屏,是什么问题呢? |
