本人写的一个测试程序,烧进去后运行不了,不知何因,还希望高手指点
ATmega128并行控制带字库的12864程序
// 液晶硬件连接:
// 1.PIN1 --- GND ---->GND
// 2.PIN2 --- VCC ---->5v
// 3.PIN3 --- V0 ---->3.2v
// 4.PIN4 --- RS ---->PORTE.3
// 5.PIN5 --- R/W ---->PORTE.4
// 6.PIN6 --- E ---->PORTE.5
// 7.PIN7 --- DB0 ---->PORTB.0
// 8.PIN8 --- DB1 ---->PORTB.1
// 9.PIN9 --- DB2 ---->PORTB.2
// 10.PIN10 --- DB3 ---->PORTB.3
// 11.PIN11 --- DB4 ---->PORTB.4
// 12.PIN12 --- DB5 ---->PORTB.5
// 13.PIN13 --- DB6 ---->PORTB.6
// 14.PIN14 --- DB7 ---->PORTB.7
// 15.PIN15 --- PSB ---->1,并行
// 16.PIN16 --- NC
// 17.PIN17 --- RST ---->5v,no reset
// 18PIN18 --- NC
// 19PIN19 --- VCC ---->5v
// 20.PIN20 --- GND ---->GND
#include <iom128v.h>
#include<macros.h>
#define BIT(x) (1 << (x))
#define SETBIT(x, y) (x |= y)
#define CLEARBIT(x, y) (x &= ~y)
#define CHECKBIT(x, y) (x & y)
#define BIT5 0x20
#define BIT4 0x10
#define BIT3 0x08
#define LCD_RS BIT3
#define LCD_RW BIT4
#define LCD_EN BIT5
/*****LCD接口定义*****/
#define LCD_RSH SETBIT(PORTE, LCD_RS) // 1:输入数据
#define LCD_RSL CLEARBIT(PORTE, LCD_RS) //0:输入命令
#define LCD_RWH SETBIT(PORTE,LCD_RW ) //1:读数据
#define LCD_RWL CLEARBIT(PORTE,LCD_RW ) //0:写数据
#define LCD_ENH SETBIT(PORTE,LCD_EN )
#define LCD_ENL CLEARBIT(PORTE,LCD_EN )
/*****汉字地址表*****/
unsigned char addr_tab[]={ //便于根据汉字坐标求出地址
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,//第一行汉字位置
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,//第二行汉字位置
0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,//第三行汉字位置
0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,//第四行汉字位置
/*****n(ms)延时子程序*****/
void delayms(unsigned int t) //约延时n(ms)
unsigned int i;
while(t--)
for(i=0;i<125;i++);
/*****等待LCD忙*****/
void WaitBusy(void) //延时一小段时间,等待LCD空闲
unsigned char i=5;
while(i--);
/*****写指令代码*****/
void Lcd_WriteCmd(unsigned char cmdcode)
LCD_RSL;
LCD_RWL;
LCD_ENH;
WaitBusy();
PORTB=cmdcode;
LCD_ENL;
/*****写数据*****/
void Lcd_WriteData(unsigned char dispdata)
LCD_RSH;
LCD_RWL;
LCD_ENH;
WaitBusy();
PORTB=dispdata;
LCD_ENH;
/*****初始化LCD*****/
void Lcd_Init()
delayms(50);
Lcd_WriteCmd(0x01); //清除显示,并且设定地址指针为00H
delayms(1);
Lcd_WriteCmd(0x30); //选择基本指令集
delayms(1);
Lcd_WriteCmd(0x30); //选择8bit数据流
delayms(1);
Lcd_WriteCmd(0x0c); //开显示(无游标、不反白)
delayms(20);
/*****显示汉字*****/
void hanzi_Disp(unsigned char x,unsigned char y,unsigned char *s)
{ //x、y为汉字坐标
Lcd_WriteCmd(addr_tab[8*x+y]); //写地址
while(*s>0)
Lcd_WriteData(*s); //写数据
s++;
/*****主函数*****/
Lcd_Init();
DDRB=0xFF;
PORTC=0x00;
Lcd_Init();
hanzi_Disp(0,0,"ST7920型液晶模块");
hanzi_Disp(1,1,"并行测试程序");
hanzi_Disp(3,3,"");
delayms(2000);
