发表于 2010-4-21 12:27:17
帮帮忙啊 完整的输出是这样的:
Uncompressing Linux...................................................................................................................... done, booting the kernel.
Linux version 2.6.30.4 (root@localhost.localdomain) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #10 Tue Apr 20 15:35:33 CST 2010
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: SMDK2410
Warning: bad configuration page, trying to continue
Memory policy: ECC disabled, Data cache writeback
CPU S3C2410A (id 0x32410002)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C2410: core 200.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064
Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0,115200 rootfstype=yaffs2
NR_IRQS:85
irq: clearing subpending status 00000002
PID hash table entries: 64 (order: 6, 256 bytes)
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 16MB = 16MB total
Memory: 12396KB available (3320K code, 278K data, 120K init, 0K highmem)
Calibrating delay loop... 99.73 BogoMIPS (lpj=249344)
CPU: Testing write buffer coherency: ok
net_namespace: 936 bytes
S3C Power Management, Copyright 2004 Simtec Electronics
S3C2410: Initialising architecture
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c1808000, irq 33
DMA channel 1 at c1808040, irq 34
DMA channel 2 at c1808080, irq 35
DMA channel 3 at c18080c0, irq 36
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
s3c2410-i2c s3c2410-i2c: slave address 0x10
s3c2410-i2c s3c2410-i2c: bus frequency set to 97 KHz
s3c2410-i2c s3c2410-i2c: i2c-0: S3C I2C adapter
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (extended precision)
yaffs Apr 19 2010 16:34:39 Installing.
msgmni has been set to 24
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
s3c2410-lcd s3c2410-lcd: no platform data for lcd, cannot attach
s3c2410-lcd: probe of s3c2410-lcd failed with error -22
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
s3c2410-uart.0: tq2440_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2410
s3c2410-uart.1: tq2440_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2410
s3c2410-uart.2: tq2440_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2410
brd: module loaded
loop: module loaded
Uniform Multi-Platform E-IDE driver
ide-gd driver 1.18
ide-cd driver 5.00
Driver 'sd' needs updating - please use bus_type methods
dm9000 Ethernet Driver, V1.31
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2410-nand s3c2410-nand: Tacls=3, 30ns Twrph0=7 70ns, Twrph1=3 30ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 3 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "EmbedSky_Board_uboot"
0x000000200000-0x000000400000 : "EmbedSky_Board_kernel"
0x000000400000-0x000003ff8000 : "EmbedSky_Board_yaffs2"
usbmon: debugfs is not available
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.4.3:USB FTDI Serial Converters Driver
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
Advanced Linux Sound Architecture Driver Version 1.0.20.
ALSA device list:
No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
yaffs: auto selecting yaffs1
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs2 filesystem) readonly on device 31:2.
Freeing init memory: 120K
Warning: unable to open an initial console.
Failed to execute /linuxrc. Attempting defaults...
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
[<c002c71c>] (unwind_backtrace+0x0/0xdc) from [<c0282ab4>] (panic+0x40/0x110)
[<c0282ab4>] (panic+0x40/0x110) from [<c00264c0>] (init_post+0xcc/0xf4)
[<c00264c0>] (init_post+0xcc/0xf4) from [<c000859c>] (kernel_init+0xb8/0xe0)
[<c000859c>] (kernel_init+0xb8/0xe0) from [<c00490d0>] (do_exit+0x0/0x578)
[<c00490d0>] (do_exit+0x0/0x578) from [<1a00000e>] (0x1a00000e |
