发表于 2010-5-12 16:11:35
找到这个
PM3 COMMAND LINE HELP
Options Description Default
# Communication Ports 1 thru 5 supported. 1
Com ports 1-4 indicates RS232, Com Port
5 indicates USB.
A VddApp Device Specific
B<Operation><path> Environment Operation None
Operation L: = Load Environment,
All paths = full file
path. All paths located
on the PM3Card must be
preceeded by a 'P' All
Paths on the computer
must be preceeded by a
'C'
Operation S: = Save Environment,
All paths = full environment
'C'
Operation D: = Delete Environment,
'C'
Operation C: = Copy Environment,
path = full file path to
the environment file of
the environemnt to be copied,
followed by the path to
the destination directory.
The two paths must be
separated by an asterisk
(*), and each path must
be preceded by either 'C'
if the path is on the
computer or 'P' if the
path is on the PM3.
Operation V: = View Environment,
the environemnt to be viewed.
All paths located
'C'
C Blank Check Device Do not Blank Check
D<file> OSSuite File Selection None
E Erase Flash Device Do Not Erase
F<file> Hex File Selection None
G<Type><range/path> Read functions None
Type F: = read into hex file,
path = full file path,
range is not used
Types P,E,I,C: = ouput read of Program,
EEPROM, ID and/or Configuration
Memory to the screen. P and E
must be followed by an address
range in the form of x-y where
x is the start address and y is
the end address both in hex,
path is not used
K Display Hex File Checksum Do Not Display
L Low voltage programming Not Selected
M<memory region> Program Device Do Not Program
memory regions:
P = Program memory
E = EEPROM
I = ID memory
C = Configuration memory
If no region is entered, the entire
device will be programmed.
N Vdd Min Device Specific
P<part> Part Selection. Example: 16f877 None
Q Quiet Mode, no screen output Quiet mode off
R<on> <off> Safe/Restricted Mode None
S<file> SQTP File Selection None
T Vdd Nominal. Device Specific
V Vpp Device Specific
W Externally power target Power from PM3
X Vdd Max Device Specific
Y<memory region> Verify Device Do Not Verify
P = Program memory
E = EEPROM
I = ID memory
device will be verified.
? Help Screen Not Shown
Each option must be immediately preceeded by a switch, Which can
be either a dash <-> or a slash </> and options must be separated
by a single space.
Example: PM3CMD /1 /P16F877 /Fc:\mycode /M
or
PM3CMD -1 -P16F877 -Fc:\mycode -M
Any option immediately followed by a question mark will envoke
a more detailed description of how to use that option.
Commands and their parameters are not case sensitive. Commands will
be processed according to command order of precedence, not the order
in which they appear on the command line. To see a list of the command
order of precedence type -?? on the command line.
The program will return an exit code upon completion which will
indicate either successful completion, or describe the reason for
failure. To view the list of exit codes and their descriptions,
type -?E on the command line.
Version 02.20.00
Copyright (C) Microchip Technology Inc. 2005 |
