void *OSQPend (OS_EVENT *pevent, INT16U timeout, INT8U *err)
#if OS_CRITICAL_METHOD == 3 /* Allocate storage for CPU status register */
OS_CPU_SR cpu_sr;
void *msg;
OS_Q *pq;
if (OSIntNesting > 0) { /* See if called from ISR ... */
*err = OS_ERR_PEND_ISR; /* ... can't PEND from an ISR */
return ((void *)0);
#if OS_ARG_CHK_EN > 0
if (pevent == (OS_EVENT *)0) { /* Validate 'pevent' */
*err = OS_ERR_PEVENT_NULL;
return ((void *)0);
if (pevent->OSEventType != OS_EVENT_TYPE_Q) {/* Validate event block type */
*err = OS_ERR_EVENT_TYPE;
return ((void *)0);
OS_ENTER_CRITICAL();
pq = (OS_Q *)pevent->OSEventPtr; /* Point at queue control block */
if (pq->OSQEntries > 0) { /* See if any messages in the queue */
msg = *pq->OSQOut++; /*疑惑这里不是取消息地址码,为什么加个*,不是变成取消息内容了 */
pq->OSQEntries--; /* Update the number of entries in the queue */
if (pq->OSQOut == pq->OSQEnd) { /* Wrap OUT pointer if we are at the end of the queue */
pq->OSQOut = pq->OSQStart;
OS_EXIT_CRITICAL();
*err = OS_NO_ERR;
return (msg); /* Return message received */
OSTCBCur->OSTCBStat |= OS_STAT_Q; /* Task will have to pend for a message to be posted */
OSTCBCur->OSTCBDly = timeout; /* Load timeout into TCB */
OS_EventTaskWait(pevent); /* Suspend task until event or timeout occurs */
OS_EXIT_CRITICAL();
OS_Sched(); /* Find next highest priority task ready to run */
msg = OSTCBCur->OSTCBMsg;
if (msg != (void *)0) { /* Did we get a message? */
OSTCBCur->OSTCBMsg = (void *)0; /* Extract message from TCB (Put there by QPost) */
OSTCBCur->OSTCBStat = OS_STAT_RDY;
OSTCBCur->OSTCBEventPtr = (OS_EVENT *)0; /* No longer waiting for event */
OS_EXIT_CRITICAL();
*err = OS_NO_ERR;
OS_EventTO(pevent); /* Timed out */
OS_EXIT_CRITICAL();
*err = OS_TIMEOUT; /* Indicate a timeout occured */
return ((void *)0); /* No message received */
