发表于 2010-7-25 11:20:35
回复【27楼】ghosthd
High Output – 3600 lumens (6500K at high efficiency) or as much as 6000 lumens (6500K at high output)
Large, single chip with an emitting surface area of 5.4 mm2
High thermal conductivity package with a package thermal resistance of only 0.96° C/W
Integrated thermistor allows for real-time monitoring of the LED’s temperature
Lumen maintenance of greater than 70% after 60,000 hours
Variable drive current from less than 1 A to 6.3 A
Available in a variety of Correlated Color Temperatures (CCT’s) per ANSI C78-377-2008
Designed with a standard on-board connector
那玩意叫做CSM——360,请看官网:http://www.luminus.com/content1520
1、是单颗,不是单核。
2、其实是提供1A-6.3A的驱动电流,LED的光效大概是100流明/w不到点,应该是高达6000流明(as much as 6000 lumens (6500K at high output) )。
如果你用水冷加压……可能会超7000. |
