发表于 2010-7-17 16:25:59
主机
#include<iom16v.h>
#include<macros.h>
#define uint unsigned int
#define xtal 8
#define CLR_BIT(x,y) (x&=~(1<<y))
#define SET_BIT(x,y) (x|=(1<<y))
#define SS 4
uchar seg[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar txbuffer[10]={0,1,2,3,4,5,6,7,8,9};
uchar i=0;
uchar temp;
void delay_ms(void)
uint i;
for(i=1;i<(uint)(xtal*143-2);i++);
void delay_nms(uint k)
uint i=0;
while(i<k)
delay_ms();
i++;
void port_init(void)
DDRA=0xff;
PORTA=0xff;
DDRB=0xb0;
PORTB=0x10;
DDRC=0xff;
PORTC=0xff;
void spi_masterinit(void)
SPCR=0x51;
void spi_mastertransmit(uchar data)
SPDR=data;
while(!(SPSR&(1<<SPIF)));
CLR_BIT(SPSR,SPIF);
uchar spi_slavereceive(void)
return SPDR;
CLR_BIT(SPSR,SPIF);
delay_nms(100);
port_init();
spi_masterinit();
CLR_BIT(PORTB,SS);
spi_mastertransmit(txbuffer);
SET_BIT(PORTB,SS);
PORTC=0xff;
PORTA=seg[txbuffer];
PORTC=0xfe;
delay_nms(500);
if(++i>9)i=0;
从机
#include<iom16v.h>
#include<macros.h>
#define xtal 8
uchar rxbuffer[10];
uchar i=0;
void delay_ms(void)
uint i;
uint i=0;
while(i<k)
delay_ms();
i++;
DDRA=0xff;
PORTA=0x00;
DDRB=0x40;
PORTB=0x10;
DDRC=0xff;
PORTC=0xff;
void spi_slaveinit(void)
SPCR=0x41;
uchar spi_slavereceive()
return SPDR;
CLR_BIT(SPSR,SPIF);
//delay_nms(50);
port_init();
spi_slaveinit();
SPDR=0x55;
rxbuffer=spi_slavereceive();
SPDR=0x55;
PORTA=seg[rxbuffer];
PORTC=0xfe;
if(++i>9)i=0;
你在protues里仿真一下吧!数码管用的是共阳极,晶振8M |
