推荐一款PIC单片机仿真软件,非常适合初学PIC单片机的朋友们,小巧、简单易学、具有交互式仿真功能,适合学习,如用于商业请购买正版!
是最新版内含补丁:点击此处下载 ourdev_567169E0OJ4Q.rar(文件大小:3.49M) (原文件名:Real Pic Simulator v1.3.0.0.rar)
国外下载链接:http://www.sonsivri.com/forum/index.php?topic=31944.0
官方网站:http://www.digitalelectrosoft.com/
下面是截图和英文介绍:
(原文件名:Visual.jpg)
Real Pic Simulator is a professional pic simulator for Microchip(tm) pic microcontrollers. The simulation process is done in real time with user interaction through different visual components. The main goal of this project is SPEED and we can proudly say that this is the fastest pic simulator on the market.
The advantages of using this tool:
-for professionals, companies - while waitting for the PCB prototyping the development of the firmware can be done, more than one developer can work on the same project (board) without the need of an extra development board
-for PIC hobbyist - you don't have to buy expensive pic emulators and pic debuggers
-save time - the PIC microcontroller is not easy to debug without the appropriate tools, Real Pic Simulator is the perfect tool for this job
All PIC compilers are supported. Real Pic Simulator imports the HEX or the COD file resulted from the compilation.
Very easy to use, after the HEX file is imported, place (drag and drop) the visual components that you want to use and make the connections.
Currently the following visual components are implemented(more to come):
-LEDs - turn LED on or off
-UART terminal (software and hardware) - serial communication
-Analog source - set analog pin values
-Push button - set inputs high or low
-Character LCD - display text on LCD
-Keypad - read up to 4x4 keypads
-7 LED segment display - LED display of seven segments
-Oscilloscope - digital oscilloscope
-Graphic LCD - display graphics on LCD
-Buzzer (speaker) - output sound to PC sound card
-Function generator - customize input streams
-I2C serial EEPROM memory - simulate a 24C64 (8KBytes) serial memory
-DS1307 Real Time Clock - read time with I2C protocol
Supported PIC microcontrollers
Baseline:
10F200 10F202 10F204 10F206 10F220 10F222 12F508 12F509 12F510 12F519 16F505 16F506 16F526 16F54 16F57 16F59
Total:16
Mid-range:
12F609 12F615 12F629 12F635 12F675 12F683 16F610 16F616 16F627 16F627A 16F628 16F628A 16F630 16F631 16F636 16F639 16F648A 16F676 16F677 16F684 16F685 16F687 16F688 16F689 16F690 16F716 16F72 16F722 16F723 16F724 16F726 16F727 16F73 16F737 16F74 16F747 16F76 16F767 16F77 16F777 16F785 16F818 16F819 16F83 16F84 16F84A 16F87 16F870 16F871 16F872 16F873 16F873A 16F874 16F874A 16F876 16F876A 16F877 16F877A 16F88 16F882 16F883 16F884 16F886 16F887 16F913 16F914 16F916 16F917 16F946
Total:69
Simulated modules
Timer0
Timer1
Timer2
EEPROM read/write and FLASH read
Interrupt-on-change
External interrupt on INT pin
CCP module
ADC module
UART module |
