U-Boot 2010.03 (Jul 14 2010 - 11:06:52)
mekearm@163.com
bootloader---ok
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: 256 MiB
Video: 240x320x16 20kHz 62Hz
In: serial
Out: serial
Err: serial
USB slave is enable!
Net: dm9000
Bootloader makearm@163.com
Linux---------------
Hit any key to stop autoboot: 0
dm9000 i/o: 0x20000300, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 12:34:56:78:9a:bc
operating at 100M full duplex mode
Using dm9000 device
File transfer via NFS from server 192.168.18.77; our IP address is 192.168.18.249
Filename '/nfs/kernel/uImage'.
Load address: 0x30008000
Loading: #################################################################
done
Bytes transferred = 2133044 (208c34 hex)
## Booting kernel from Legacy Image at 30008000 ...
Image Name: linux-2.6.34
Created: 2010-07-15 10:36:40 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2132980 Bytes = 2 MB
Load Address: 30008000
Entry Point: 30008040
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.34 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #6 Thu Jul 15 18:36:28 CST 2010
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: MakeArm Love Linux
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd root=/dev/nfs rw nfsroot=192.168.18.77:/nfs/rootfs ip=192.168.18.249:192.168.18.77:255.255.255.0 console=ttySAC0,115200 init=/linuxrc mem=64M
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 60520k/60520k available, 5016k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc4800000 - 0xe0000000 ( 440 MB)
lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0030000 ( 160 kB)
.text : 0xc0030000 - 0xc03cd000 (3700 kB)
.data : 0xc03ec000 - 0xc0414c60 ( 164 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:85
irq: clearing pending status 02000000
irq: clearing subpending status 00000002
Console: colour dummy device 80x30
console [ttySAC0] enabled
Calibrating delay loop... 201.93 BogoMIPS (lpj=504832)
CPU: Testing write buffer coherency: ok
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
Advanced Linux Sound Architecture Driver Version 1.0.22.1.
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
ROMFS MTD (C) 2007 Red Hat, Inc.
msgmni has been set to 118
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Console: switching to colour frame buffer device 30x20
fb0: s3c2410fb frame buffer device
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
s3c24xx-nand s3c2440-nand: NAND soft ECC
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 586 at 0x000004940000
Bad eraseblock 1795 at 0x00000e060000
Bad eraseblock 1837 at 0x00000e5a0000
Bad eraseblock 1956 at 0x00000f480000
Creating 5 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "U-Boot 2010.03 Makearm"
0x000000040000-0x000000060000 : "param"
0x000000060000-0x000000560000 : "kernel"
0x000000560000-0x000040560000 : "root"
mtd: partition "root" extends beyond the end of device "NAND 256MiB 3,3V 8-bit" -- size truncated to 0xfaa0000
0x000000000000-0x000040000000 : "nand"
mtd: partition "nand" extends beyond the end of device "NAND 256MiB 3,3V 8-bit" -- size truncated to 0x10000000
dm9000 Ethernet Driver, V1.31
eth0: dm9000e at c486e300,c4872304 IRQ 51 MAC: aa:bb:cc:dd:ee:ff (chip)
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
i2c /dev entries driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
cpuidle: using governor ladder
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
ALSA device list:
No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
eth0: link down
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Gateway not on directly connected network.
Looking up port of RPC 100003/2 on 192.168.18.77
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Looking up port of RPC 100005/1 on 192.168.18.77
VFS: Mounted root (nfs filesystem) on device 0:13.
Freeing init memory: 160K
/etc/init.d/rcS: line 6: exprot: not found
----------munt all------------
mdev: /sys/block: No such file or directory
mdev: /sys/class: No such file or directory
----------makearm@163.com-----------------------
----------kernel version:linux2.32.2------------
Processing /etc/profile... Done
-/bin/sh: exprot: not found
[root@MrMakearm=W]# |
