发表于 2010-10-15 22:17:34
回复【10楼】abutter
File name: flex_lcd.h
Company:
Note:
/*History
DATE: 2009-11-27
File Version: 0.0.1.0
2010-5-12 v0.0.1.1
///* flex_lcd.h
These pins are for the Microchip PicDem2-Plus board,
which is what I used to test the driver. Change these
pins to fit your own board.
lcd_init() Must be called before any other function.
lcd_putc(c) Will display c on the next position of the LCD.
The following have special meaning:
\f Clear display
\n Go to start of second line
\b Move back one position
-------------2010-5-12 WangJiati
\| ON Flashing Cursor
\! OFF Flashing Cursor
\> Cursor or Display Shift
lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)
lcd_getc(x,y) Returns character at position x,y on LCD
#define LCD_DB4 PIN_B4
#define LCD_DB5 PIN_B5
#define LCD_DB6 PIN_B6
#define LCD_DB7 PIN_B7
#define LCD_E PIN_A5
#define LCD_RS PIN_A4
//#define LCD_RW PIN_A5
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
//#define USE_LCD_RW 1
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
//// prototyping of functions
void lcd_send_nibble(int8 nibble) ;
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void) ;
#ifdef USE_LCD_RW
int8 lcd_read_byte(void) ;
void lcd_send_byte(int8 address, int8 n) ;
void lcd_init(void) ;
void lcd_gotoxy(int8 x, int8 y) ;
void lcd_putc(char c,) ;
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y) ;
File name: flex_lcd.c
Company:
Note:
/*History
DATE: 2009-11-27
2010-5-12 v0.0.1.1
/* flex_lcd.c
\f Clear display
-------------2010-5-12 Wangjiati
#define LCD_DB4 PIN_D0
#define LCD_DB5 PIN_D1
#define LCD_DB6 PIN_D2
#define LCD_DB7 PIN_D3
#define LCD_E PIN_A1
#define LCD_RS PIN_A3
#define LCD_RW PIN_A2
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
// Note: !! converts an integer expression
// to a boolean (1 or 0).
output_bit(LCD_DB4, !!(nibble & 1));
output_bit(LCD_DB5, !!(nibble & 2));
output_bit(LCD_DB6, !!(nibble & 4));
output_bit(LCD_DB7, !!(nibble & 8));
delay_cycles(2);
output_high(LCD_E);
delay_us(5);
output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine. For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return(retval);
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
// Send a byte to the LCD.
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
if(address)
output_high(LCD_RS);
output_low(LCD_RS);
delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
lcd_send_nibble(0x03);
delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
lcd_send_byte(0, LCD_INIT_STRING);
// If the R/W signal is not used, then
// the busy bit can't be polled. One of
// the init commands takes longer than
// the hard-coded delay of 60 us, so in
// that case, lets just do a 5 ms delay
// after all four of them.
#ifndef USE_LCD_RW
delay_ms(5);
int8 address;
if(y != 1)
address = lcd_line_two;
address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
switch(c)
case '\f':
lcd_send_byte(0,1);
delay_ms(2);
case '\n':
lcd_gotoxy(1,2);
case '\b':
lcd_send_byte(0,0x10);
case '\|':
lcd_send_byte(0,0x0f);
case '\!':
lcd_send_byte(0,0x0c);
case '\>':
lcd_send_byte(0,0x14);
case '\h':
lcd_send_byte(0,0x02);
default:
lcd_send_byte(1,c);
#ifdef USE_LCD_RW
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
以上是LCD驱动 |
