发表于 2010-12-8 14:54:34
回复【楼主位】ldsheng
; <<< Use Configuration Wizard in Context Menu >>>
; Startup.s - Startup code for Stellaris.
; Copyright (c) 2006-2008 Luminary Micro, Inc. All rights reserved.
; Software License Agreement
; Luminary Micro, Inc. (LMI) is supplying this software for use solely and
; exclusively on LMI's microcontroller products.
; The software is owned by LMI and/or its suppliers, and is protected under
; applicable copyright laws. All rights are reserved. You may not combine
; this software with "viral" open-source software in order to form a larger
; program. Any use in violation of the foregoing restrictions may subject
; the user to criminal sanctions under applicable laws, as well as to civil
; liability for the breach of the terms and conditions of this license.
; THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED
; OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
; MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
; LMI SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
; CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
; This is part of revision 2523 of the Stellaris Peripheral Driver Library.
; <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
Stack EQU 0x00000800
; <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
Heap EQU 0x00000800
; Allocate space for the stack.
AREA STACK, NOINIT, READWRITE, ALIGN=3
StackMem
SPACE Stack
__initial_sp
; Allocate space for the heap.
AREA HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
HeapMem
SPACE Heap
__heap_limit
; Indicate that the code in this file preserves 8-byte alignment of the stack.
PRESERVE8
; Place code into the reset code section.
AREA RESET, CODE, READONLY
EXTERN UARTIntHandler
THUMB
; The vector table.
EXPORT __Vectors
__Vectors
DCD StackMem + Stack ; Top of Stack
DCD Reset_Handler ; Reset Handler
DCD NmiSR ; NMI Handler
DCD FaultISR ; Hard Fault Handler
DCD IntDefaultHandler ; MPU Fault Handler
DCD IntDefaultHandler ; Bus Fault Handler
DCD IntDefaultHandler ; Usage Fault Handler
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD IntDefaultHandler ; SVCall Handler
DCD IntDefaultHandler ; Debug Monitor Handler
DCD 0 ; Reserved
DCD IntDefaultHandler ; PendSV Handler
DCD IntDefaultHandler ; SysTick Handler
DCD IntDefaultHandler ; GPIO Port A
DCD IntDefaultHandler ; GPIO Port B
DCD IntDefaultHandler ; GPIO Port C
DCD IntDefaultHandler ; GPIO Port D
DCD IntDefaultHandler ; GPIO Port E
DCD UARTIntHandler ; UART0
DCD IntDefaultHandler ; UART1
DCD IntDefaultHandler ; SSI
DCD IntDefaultHandler ; I2C
DCD IntDefaultHandler ; PWM Fault
DCD IntDefaultHandler ; PWM Generator 0
DCD IntDefaultHandler ; PWM Generator 1
DCD IntDefaultHandler ; PWM Generator 2
DCD IntDefaultHandler ; Quadrature Encoder
DCD IntDefaultHandler ; ADC Sequence 0
DCD IntDefaultHandler ; ADC Sequence 1
DCD IntDefaultHandler ; ADC Sequence 2
DCD IntDefaultHandler ; ADC Sequence 3
DCD IntDefaultHandler ; Watchdog
DCD IntDefaultHandler ; Timer 0A
DCD IntDefaultHandler ; Timer 0B
DCD IntDefaultHandler ; Timer 1A
DCD IntDefaultHandler ; Timer 1B
DCD IntDefaultHandler ; Timer 2A
DCD IntDefaultHandler ; Timer 2B
DCD IntDefaultHandler ; Comp 0
DCD IntDefaultHandler ; Comp 1
DCD IntDefaultHandler ; Comp 2
DCD IntDefaultHandler ; System Control
DCD IntDefaultHandler ; Flash Control
DCD IntDefaultHandler ; GPIO Port F
DCD IntDefaultHandler ; GPIO Port G
DCD IntDefaultHandler ; GPIO Port H
DCD IntDefaultHandler ; UART2 Rx and Tx
DCD IntDefaultHandler ; SSI1 Rx and Tx
DCD IntDefaultHandler ; Timer 3 subtimer A
DCD IntDefaultHandler ; Timer 3 subtimer B
DCD IntDefaultHandler ; I2C1 Master and Slave
DCD IntDefaultHandler ; Quadrature Encoder 1
DCD IntDefaultHandler ; CAN0
DCD IntDefaultHandler ; CAN1
DCD IntDefaultHandler ; CAN2
DCD IntDefaultHandler ; Ethernet
DCD IntDefaultHandler ; Hibernate
DCD IntDefaultHandler ; USB0
DCD IntDefaultHandler ; PWM Generator 3
DCD IntDefaultHandler ; uDMA Software Transfer
DCD IntDefaultHandler ; uDMA Error
; This is the code that gets called when the processor first starts execution
; following a reset event.
EXPORT Reset_Handler
Reset_Handler
; Call the C library enty point that handles startup. This will copy
; the .data section initializers from flash to SRAM and zero fill the
; .bss section.
IMPORT __main
B __main
; This is the code that gets called when the processor receives a NMI. This
; simply enters an infinite loop, preserving the system state for examination
; by a debugger.
NmiSR
B NmiSR
; This is the code that gets called when the processor receives a fault
; interrupt. This simply enters an infinite loop, preserving the system state
; for examination by a debugger.
FaultISR
B FaultISR
; This is the code that gets called when the processor receives an unexpected
IntDefaultHandler
B IntDefaultHandler
; Make sure the end of this section is aligned.
ALIGN
; Some code in the normal code section for initializing the heap and stack.
AREA |.text|, CODE, READONLY
; The function expected of the C library startup code for defining the stack
; and heap memory locations. For the C library version of the startup code,
; provide this function so that the C library initialization code can find out
; the location of the stack and heap.
IF :DEF: __MICROLIB
EXPORT __initial_sp
EXPORT __heap_base
EXPORT __heap_limit
ELSE
IMPORT __use_two_region_memory
EXPORT __user_initial_stackheap
LDR R0, =HeapMem
LDR R1, =(StackMem + Stack)
LDR R2, =(HeapMem + Heap)
LDR R3, =StackMem
BX LR
ENDIF
ALIGN
; Tell the assembler that we're done.
END |
