如下是uCGUI在在uCOS下时相关的参考代码
* uC/GUI V3.98
* Universal graphic software for embedded applications
* (c) Copyright 2002, Micrium Inc., Weston, FL
* (c) Copyright 2002, SEGGER Microcontroller Systeme GmbH
* 礐/GUI is protected by international copyright laws. Knowledge of the
* source code may not be used to write a similar product. This file may
* only be used in accordance with a license and should not be redistributed
* in any way. We appreciate your understanding and fairness.
---Author-Explanation
* 1.00.00 020519 JJL First release of uC/GUI to uC/OS-II interface
* Known problems or limitations with current version
* None.
* Open issues
* None
#include <ucos_ii.h>
#include "GUI_Private.H"
#include "stdio.H"
* GLOBAL VARIABLES
static OS_EVENT *DispSem;
static OS_EVENT *EventMbox;
static OS_EVENT *KeySem;
static int KeyPressed;
static char KeyIsInited;
* TIMING FUNCTIONS
* Notes: Some timing dependent routines of uC/GUI require a GetTime and delay funtion.
* Default time unit (tick), normally is 1 ms.
int GUI_X_GetTime (void)
return ((int)OSTimeGet());
void GUI_X_Delay (int period)
INT32U ticks;
ticks = (period * 1000) / OS_TICKS_PER_SEC;
OSTimeDly((INT16U)ticks);
* GUI_X_ExecIdle()
void GUI_X_ExecIdle (void)
OS_X_Delay(1);
* MULTITASKING INTERFACE FUNCTIONS
* Note(1): 1) The following routines are required only if uC/GUI is used in a true multi task environment,
* which means you have more than one thread using the uC/GUI API. In this case the #define
* GUI_OS 1 needs to be in GUIConf.h
void GUI_X_InitOS (void)
DispSem = OSSemCreate(1);
EventMbox = OSMboxCreate((void *)0);
void GUI_X_Lock (void)
INT8U err;
OSSemPend(DispSem, 0, &err);
void GUI_X_Unlock (void)
OSSemPost(DispSem);
U32 GUI_X_GetTaskId (void)
return ((U32)(OSTCBCur->OSTCBPrio));
* GUI_X_WaitEvent()
* GUI_X_SignalEvent()
void GUI_X_WaitEvent (void)
INT8U err;
(void)OSMboxPend(EventMbox, 0, &err);
void GUI_X_SignalEvent (void)
(void)OSMboxPost(EventMbox, (void *)1);
* KEYBOARD INTERFACE FUNCTIONS
* Purpose: The keyboard routines are required only by some widgets.
* If widgets are not used, they may be eliminated.
* Note(s): If uC/OS-II is used, characters typed into the log window will be placed in the keyboard buffer.
* This is a neat feature which allows you to operate your target system without having to use or
* even to have a keyboard connected to it. (useful for demos !)
static void CheckInit (void)
if (KeyIsInited == FALSE) {
KeyIsInited = TRUE;
GUI_X_Init();
void GUI_X_Init (void)
KeySem = OSSemCreate(0);
int GUI_X_GetKey (void)
int r;
r = KeyPressed;
CheckInit();
KeyPressed = 0;
return (r);
int GUI_X_WaitKey (void)
int r;
INT8U err;
CheckInit();
if (KeyPressed == 0) {
OSSemPend(KeySem, 0, &err);
r = KeyPressed;
KeyPressed = 0;
return (r);
void GUI_X_StoreKey (int k)
KeyPressed = k;
OSSemPost(KeySem);
