发表于 2011-3-19 12:37:34
http://www.beam-wiki.org/wiki/FLED-based_Solar_Engine
The idea here is that when the FLED flashes (at about 2.4 volts), it conducts. This makes the base of the PNP transistor (here shown as a 2N3906, but you could also use a BC327) go "low," so it triggers, which makes the base of the NPN transistor (here shown as a 2N3904, but you could also use a BC337) go "high," and when it triggers, current is applied through the motor. Note that once the NPN transistor triggers, the FLED is essentially out of the circuit; the motor is then given power until the transistors go inactive at about 0.7 V. |
