/* FILE :R5F212L.c */
/* This file is generated by Renesas Project Generator (Ver.4.12). */
/* //对一个块中的数据写入时,必须对整个的块擦除 */
#include "sfr_r82l.h"
/* Definition of const data */
#define BLOCK_A ((unsigned char *)0x2400) /* BLOCK A first address */
#define BLOCK_A_END ((unsigned char *)0x27ff) /* BLOCK A last address */
#define BLOCK_B ((unsigned char *)0x2800) /* BLOCK B first address */
#define BLOCK_B_END ((unsigned char *)0x2Bff) /* BLOCK B last address */
#define RECORD_PER_BLOCK 1 /* Record number per 1 block */
#define RECORD_SIZE 1024 /* Record size */
#define BLOCK_A_SELECT 0 /* Use BLOCK A */
#define BLOCK_B_SELECT 1 /* Use BLOCK B */
/* Declaration of function prototype */
void write_address_init(void);
unsigned char flash_write(unsigned char *data);
unsigned char block_erase(unsigned char *ers_addr);
unsigned char data_write(unsigned char *write_data);
void make_data(unsigned char *write_data);
static unsigned char write_data[RECORD_SIZE]; /* wirte data */
unsigned char result;
unsigned int i = 0;
-Change on-chip oscillator clock to Main clock -
prc0 = 1; /* Protect off */
cm13 = 1; /* Xin Xout */
cm15 = 1; /* XCIN-XCOUT drive capacity select bit : HIGH */
cm05 = 0; /* Xin on */
while( i <= 255 ) i++; /* This setting is an example of waiting time for the */
/* oscillation stabilization. Please evaluate the time */
/* for oscillation stabilization by a user. */
ocd2 = 0; /* Main clock change */
cm16 = 0; /* Main clock = No division mode */
cm17 = 0;
cm06 = 0; /* CM16 and CM17 enable */
prc0 = 0; /* Protect on */
Parameters: Record data pointer
Returns: None
Description: Make record data
void make_data(unsigned char *data)
/* Make record data */
data[0]=40;
data[10]=50;
data[12]=60;
Parameters: None
Returns: None
Description: Write address initialize
int i;
int j;
if(write_addr >= BLOCK_B_END+1)
/* if BLOCK A and BLOCK B are full then BLOCK A erase */
block_erase(BLOCK_A);
write_addr = BLOCK_A;
block_select = BLOCK_A_SELECT;
else if(write_addr >= BLOCK_B)
/* Use BLOCK B */
block_select = BLOCK_B_SELECT;
/* Use BLOCK A */
Parameters: Write record data
Returns: Result (Complete or program error or erase error)
Description: Initial setting of SFR registers
unsigned char result = COMPLETE;
if( data_write( data ) != COMPLETE )
/* Program error occurence */
result = result | PROGRAM_ERR; /* if program error */
/* Next write address update */
write_addr = write_addr + RECORD_SIZE;
/* If use interrupt then set i flag... */
/* asm("fset i "); */
return erase_result;
Parameters: Record data address
Returns: Program result
Description: Record program
unsigned char data_write( unsigned char *write_data )
unsigned char program_result = COMPLETE;
int i; /* loop counter */
/* If use interrupt then clear i flag... */
/* asm("fclr i "); */
/* flash control register set */
fmr0 = 0x01;
asm(" "); /* Description for preventing the abbreviation by optimization */
fmr0 = 0x03; /* CPU rewrite enable */
fmr1 = 0x80;
fmr1 = 0x82; /* EW1 mode */
