发表于 2011-4-13 13:57:12
sequential方式相比raw方式,多的数据结构:
struct netbuf {
struct pbuf *p, *ptr;//数据包相关部分
struct ip_addr *addr;//ip地址
u16_t port;//端口号
/** A netconn descriptor */
struct netconn {
/** type of the netconn (TCP, UDP or RAW) */
enum netconn_type type;
/** current state of the netconn */
enum netconn_state state;
/** the lwIP internal protocol control block */
union {
struct ip_pcb *ip;
struct tcp_pcb *tcp;
struct udp_pcb *udp;
struct raw_pcb *raw;
} pcb;
/** the last error this netconn had */
err_t err;
/** sem that is used to synchroneously execute functions in the core context */
sys_sem_t op_completed;
/** mbox where received packets are stored until they are fetched
by the netconn application thread (can grow quite big) */
sys_mbox_t recvmbox;
/** mbox where new connections are stored until processed
by the application thread */
sys_mbox_t acceptmbox;
/** only used for socket layer */
int socket;
#if LWIP_SO_RCVTIMEO
/** timeout to wait for new data to be received
(or connections to arrive for listening netconns) */
int recv_timeout;
#endif /* LWIP_SO_RCVTIMEO */
#if LWIP_SO_RCVBUF
/** maximum amount of bytes queued in recvmbox */
int recv_bufsize;
#endif /* LWIP_SO_RCVBUF */
u16_t recv_avail;
/** TCP: when data passed to netconn_write doesn't fit into the send buffer,
this temporarily stores the message. */
struct api_msg_msg *write_msg;
this temporarily stores how much is already sent. */
int write_offset;
#if LWIP_TCPIP_CORE_LOCKING
this temporarily stores whether to wake up the original application task
if data couldn't be sent in the first try. */
u8_t write_delayed;
#endif /* LWIP_TCPIP_CORE_LOCKING */
/** A callback function that is informed about events for this netconn */
netconn_callback callback;
