发表于 2011-5-7 00:39:56
上面两位说的对,3.4.0库里面SysTick关键函数就是SysTick_Config(),SystemCoreClock = 72 000 000 Hz,实际上SysTick_Config()的参数就是计数重装初值,(SystemCoreClock / 1000)这个参数是计时1ms所需要的计数初值,也就是72000。计满72000也就是1ms就进入中断,等待这样的1000次中断之后,灯开始亮和灭。(点灯为例,便于说明问题,精确的1s延时交替亮灭。最重要是动手写,说出来用处不大,下面的代码可以作为工程代码烧到板子上调试。)
**File:main.h
#ifdef __main_h
#define __main_h
#include "stm32f10x.h"
void TimingDelayDecrement(void);
**File:main.c
#include "main.h"
#define __IO uint32_t nTime;
void Delay( __IO uint_t nTime );
void RCC_Configuration(void);
void GPIO_Configuration(void);
int main(void)
SystemInit();
RCC_Configuration();
GPIO_Configuration();
SysTick_Config( SystemCoreClock / 1000 );
if( SysTick_Config( SystemCoreClock / 1000 ))
while(1);
while (1)
GPIO_ResetBits( GPIOB, GPIO_Pin_12 );
Delay( 1000 );
GPIO_SetBits( GPIOB, GPIO_Pin_12 );
Delay( 1000 );
void Delay( __IO uint32_t nTime )
TimingDelay = nTime;
while( TimingDelay !=0 );
void TimingDelay_Decrement(void)
if( TimingDelay != 0x00 )
TimingDelay--;
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init( GPIOB, &GPIO_InitStructure );
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
while (1)
**File:stm32f10x_it.c
#include "main.h"
#include "stm32f10x_it.h"
void SysTick_Handler(void)
TimingDelay_Decrement();
