发表于 2011-7-17 10:45:08
mini2440中uart是这样配置的,供参考
/* UART0 port configure */
GPHCON |= 0xAA;
/* PULLUP is disable */
GPHUP |= 0xF;
/* FIFO enable, Tx/Rx FIFO clear */
uart0.uart_device->ufcon = 0x0;
/* disable the flow control */
uart0.uart_device->umcon = 0x0;
/* Normal,No parity,1 stop,8 bit */
uart0.uart_device->ulcon = 0x3;
* tx=level,rx=edge,disable timeout int.,enable rx error int.,
* normal,interrupt or polling
uart0.uart_device->ucon = 0x245;
/* Set uart0 bps */
uart0.uart_device->ubrd = (rt_int32_t)(PCLK / (BPS * 16)) - 1;
/* output PCLK to UART0/1, PWMTIMER */
CLKCON |= 0x0D00;
/* install uart0 isr */
INTSUBMSK &= ~(BIT_SUB_RXD0);
rt_hw_interrupt_install(INTUART0, rt_serial0_handler, RT_NULL);
rt_hw_interrupt_umask(INTUART0); |
