Product : Isolated High precision Analog Output Board for PCI
Product Code : DAI16-4C(PCI)
DAI12-4C(PCI) PCI bus-compliant interface boards that performs digital-to-analog conversion. DA16-4C(PCI) performs D-A conversion using 4 output channels at a conversion speed of 20 μsec and a resolution of 16 bits. Using the bundled driver library [API-PAC(W32)], you can create Windows application software for this board in your favorite programming language supporting Win32 API functions, such as Visual Basic or Visual C++.
Safe Standard : CE;
environmental correspondence : -;
Function :
Compatible with voltage and current output: Compatible not only with voltage output (-10V to +10V and 0V to +10V) but also with current output (0mA to 20mA).
Capable of updating the output voltage using a sampling clock: The board can update the output voltage periodically using the internal sampling clock or in synchronization with external events using an external sampling clock.
Installed with voltage output control relays. All channel voltages are output via relays. These relays prevent unnecessary voltage output from occurring during power-up.
Option apparatus: By using option apparatus, connection can be performed easily.
Analog I/O :
Bus : PCI;
Function : Output;
The number of input channels : -;
The number of output channels : 4ch;
Resolution : 16bit;
Input range : -;
Output range : 10V; 0 - 10V; 0 - 20mA; |
