发表于 2011-10-15 11:52:18
#include <reg52.h>
#include <intrins.h>
#include <string.h>
#define uint unsigned int
#define disdata P0 //显示数据码输出口
bit flag;
sbit SCL=P1^2; // 将p1.0口模拟时钟口
sbit SDA=P1^3; // 将p1.3口模拟数据口
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
sbit K1 = P1^4;
sbit K2 = P1^5; //选择健
sbit K3 = P1^6; //启动健
sbit K4 = P1^7; //停止健
sbit BEEP = P3^6; //蜂鸣器
uchar code dis1[] = {" PCF-8591 "};
uchar code dis2[] = {" DA CONVERTER "};
uchar code dis3[] = {" K2: D/A CHOOSE "};
uchar code dis4[] = {"K3:ENTER K4:EXIT"};
uchar code dis5[] = {" SINE WAVE "};
uchar code dis6[] = {" SQUARE WAVE "};
uchar code dis7[] = {" TRIANGLE WAVE "};
uchar code dis8[] = {" SAWTOOTH WAVE "};
bit out1=0,out2=0,out3=0,out4=0,START=0;
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
bit bdata SystemError; //从机错误标志位
uchar N=0x00,k_count;
/*********************** PCF8591专用变量定义 ***********************/
#define PCF8591_WRITE 0x90
#define PCF8591_READ 0x91
#define NUM 4 //接收和发送缓存区的深度
uchar idata receivebuf[NUM]; //数据接收缓冲区
uchar code sin_tab[] = //正弦波输出表
0x80,0x83,0x86,0x89,0x8D,0x90,0x93,0x96,0x99,0x9C,0x9F,0xA2,0xA5,0xA8,0xAB,0xAE,
0xB1,0xB4,0xB7,0xBA,0xBC,0xBF,0xC2,0xC5,0xC7,0xCA,0xCC,0xCF,0xD1,0xD4,0xD6,0xD8,
0xDA,0xDD,0xDF,0xE1,0xE3,0xE5,0xE7,0xE9,0xEA,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4,0xF5,
0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,
0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEA,0xE9,0xE7,0xE5,0xE3,0xE1,0xDF,0xDD,0xDA,
0xD8,0xD6,0xD4,0xD1,0xCF,0xCC,0xCA,0xC7,0xC5,0xC2,0xBF,0xBC,0xBA,0xB7,0xB4,0xB1,
0xAE,0xAB,0xA8,0xA5,0xA2,0x9F,0x9C,0x99,0x96,0x93,0x90,0x8D,0x89,0x86,0x83,0x80,
0x80,0x7C,0x79,0x76,0x72,0x6F,0x6C,0x69,0x66,0x63,0x60,0x5D,0x5A,0x57,0x55,0x51,
0x4E,0x4C,0x48,0x45,0x43,0x40,0x3D,0x3A,0x38,0x35,0x33,0x30,0x2E,0x2B,0x29,0x27,
0x25,0x22,0x20,0x1E,0x1C,0x1A,0x18,0x16,0x15,0x13,0x11,0x10,0x0E,0x0D,0x0B,0x0A,
0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
0x0A,0x0B,0x0D,0x0E,0x10,0x11,0x13,0x15,0x16,0x18,0x1A,0x1C,0x1E,0x20,0x22,0x25,
0x27,0x29,0x2B,0x2E,0x30,0x33,0x35,0x38,0x3A,0x3D,0x40,0x43,0x45,0x48,0x4C,0x4E,
0x51,0x55,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,0x6C,0x6F,0x72,0x76,0x79,0x7C,0x7E
/* 延时函数 */
void delayB(uchar x) //x*0.14MS
uchar i;
while(x--)
for (i=0; i<13; i++)
/* 延时函数 */
void delay(int ms)
while(ms--)
uchar i;
for(i=0;i<250;i++)
_nop_();
_nop_();
_nop_();
_nop_();
/* 蜂鸣器函数 */
void beep()
uchar j;
for (j=0;j<180;j++)
delayB(5);
BEEP=!BEEP; //BEEP取反
BEEP=1; //关闭蜂鸣器
delay(100);
/*检查LCD忙状态 */
/*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。 */
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*写指令数据到LCD */
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。 */
void lcd_wcmd(uchar cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/*写显示数据到LCD */
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。 */
void lcd_wdat(uchar dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/* LCD初始化设定 */
void lcd_init()
delay(15);
lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据
delay(5);
lcd_wcmd(0x38);
delay(5);
lcd_wcmd(0x38);
delay(5);
lcd_wcmd(0x0c); //显示开,关光标
delay(5);
lcd_wcmd(0x06); //移动光标
delay(5);
lcd_wcmd(0x01); //清除LCD的显示内容
delay(5);
/* 设定显示位置 */
void lcd_pos(uchar pos)
lcd_wcmd(pos | 0x80); //数据指针=80+地址变量
// 函数名称: iic_start()
// 函数功能: 启动I2C总线子程序
void iic_start(void)
{ //时钟保持高,数据线从高到低一次跳变,I2C通信开始
SDA = 1;
SCL = 1;
delayNOP(); // 延时5us
SDA = 0;
delayNOP();
SCL = 0;
// 函数名称: iic_stop()
// 函数功能: 停止I2C总线数据传送子程序
void iic_stop(void)
SDA = 0; //时钟保持高,数据线从低到高一次跳变,I2C通信停止
SCL = 1;
delayNOP();
SDA = 1;
delayNOP();
SCL = 0;
// 函数名称: iicInit_()
// 函数功能: 初始化I2C总线子程序
void iicInit(void)
SCL = 0;
iic_stop();
// 函数名称: slave_ACK
// 函数功能: 从机发送应答位子程序
void slave_ACK(void)
SDA = 0;
SCL = 1;
delayNOP();
SCL = 0;
// 函数名称: slave_NOACK
// 函数功能: 从机发送非应答位子程序,迫使数据传输过程结束
void slave_NOACK(void)
SDA = 1;
SCL = 1;
delayNOP();
SDA = 0;
SCL = 0;
// 函数名称: check_ACK
// 函数功能: 主机应答位检查子程序,迫使数据传输过程结束
void check_ACK(void)
SDA = 1; // 将p1.1设置成输入,必须先向端口写1
SCL = 1;
flag = 0;
delayNOP();
if(SDA == 1) // 若SDA=1表明非应答,置位非应答标志flag
flag = 1;
SCL = 0;
// 函数名称: IICSendByte
// 入口参数: ch
// 函数功能: 发送一个字节
void IICSendByte(uchar ch)
unsigned char idata n=8; // 向SDA上发送一位数据字节,共八位
while(n--)
if((ch&0x80) == 0x80) // 若要发送的数据最高位为1则发送位1
SDA = 1; // 传送位1
SCL = 1;
delayNOP();
// SDA = 0;
SCL = 0;
SDA = 0; // 否则传送位0
SCL = 1;
delayNOP();
SCL = 0;
ch = ch<<1; // 数据左移一位
// 函数名称: IICreceiveByte
// 返回接收的数据
// 函数功能: 接收一字节子程序
uchar IICreceiveByte(void)
uchar idata n=8; // 从SDA线上读取一上数据字节,共八位
uchar tdata=0;
while(n--)
SDA = 1;
SCL = 1;
tdata =tdata<<1; //左移一位
if(SDA == 1)
tdata = tdata|0x01; // 若接收到的位为1,则数据的最后一位置1
tdata = tdata&0xfe; // 否则数据的最后一位置0
SCL = 0;
return(tdata);
// 函数名称: DAC_PCF8591
// 入口参数: slave_add从机地址,n要发送的数据个数
// 函数功能: 发送n位数据子程序
void DAC_PCF8591(uchar controlbyte)
iic_start(); // 启动I2C
delayNOP();
IICSendByte(PCF8591_WRITE); // 发送地址位
check_ACK(); // 检查应答位
if(flag == 1)
SystemError = 1;
return; // 若非应答,置错误标志位
IICSendByte(controlbyte&0x77); //Control byte
check_ACK(); //检查应答位
if(flag == 1)
SystemError = 1;
// 函数名称: ADC_PCF8591
// 入口参数: controlbyte控制字
// 函数功能: 连续读入4路通道的A/D转换结果到receivebuf
void ADC_PCF8591(uchar controlbyte)
uchar idata i; //,receive_da;
iic_start();
IICSendByte(PCF8591_WRITE); //控制字
check_ACK();
if(flag == 1)
SystemError = 1;
return;
IICSendByte(controlbyte); //控制字
check_ACK();
if(flag == 1)
SystemError = 1;
return;
iic_start(); //重新发送开始命令
IICSendByte(PCF8591_READ); //控制字
check_ACK();
if(flag == 1)
SystemError = 1;
return;
IICreceiveByte(); //空读一次,调整读顺序
slave_ACK(); //收到一个字节后发送一个应答位
// while(i<4)
for(i=0;i<4;i++)
// receive_da=IICreceiveByte();
// receivebuf=receive_da;
receivebuf = IICreceiveByte();
slave_NOACK(); //收到最后一个字节后发送一个非应答位
iic_stop();
输出三角波
void Triangle()
uchar l;
for(l=0;l<255;l++)
IICSendByte(l); //data byte
if(flag == 1)
SystemError = 1;
return; //置错误标志位SystemError
for(l=255;l>1;l--)
if(flag == 1)
SystemError = 1;
输出方波函数
void Square()
IICSendByte(N); //data byte
if(flag == 1)
SystemError = 1;
delay(15);
N=~N;
输出正弦波函数
void sin()
uint i;
for(i=0; i<256; i++)
IICSendByte(sin_tab); //data byte
if(flag == 1)
SystemError = 1;
输出锯齿波函数
void Sawtooth()
uchar l;
for(l=0;l<255;l++)
if(flag == 1)
SystemError = 1;
功能健函数
void keyscan()
uchar m;
if((K2==0)&(!START)) //启动输出后,屏蔽K2健
k_count++;
beep();
switch (k_count)
case 1:
lcd_pos(0x00);
for(m=0;m<16;m++)
lcd_wdat(dis2[m]);
lcd_pos(0x40);
for(m=0;m<16;m++)
lcd_wdat(dis5[m]);
out1=1;
out4=0;
case 2:
lcd_pos(0x40);
for(m=0;m<16;m++)
lcd_wdat(dis6[m]);
out1=0;
out2=1;
case 3:
lcd_pos(0x40);
for(m=0;m<16;m++)
lcd_wdat(dis7[m]);
out2=0;
out3=1;
case 4:
lcd_pos(0x40);
for(m=0;m<16;m++)
lcd_wdat(dis8[m]);
k_count=0;
out3=0;
out4=1;
default:
out4=0; out3=0; out2=0; out1=0;
if(K3==0) //启动输出
START=1;
beep();
if(K4==0) //停止输出
START=0;
beep();
/* 主函数 */
main()
uchar i;
delay(10); //延时
lcd_init(); //初始化LCD
lcd_pos(0); //设置显示位置为第一行
for(i=0;i<16;i++)
lcd_wdat(dis1); //显示字符
lcd_pos(0x40); //设置显示位置为第二行
for(i=0;i<16;i++)
lcd_wdat(dis2); //显示字符
delay(1500);
for(i=0;i<16;i++)
lcd_wdat(dis3); //显示字符
for(i=0;i<16;i++)
lcd_wdat(dis4); //显示字符
DAC_PCF8591(0x40);
keyscan();
while(out1&START)
sin(); //输出正弦波
keyscan();
while(out2&START)
Square(); //输出方波
keyscan();
while(out3&START)
Triangle(); //输出三角波
keyscan();
while(out4&START)
Sawtooth(); //输出锯齿波
keyscan();
