Uncompressing Linux... done, booting the kernel.
Linux version 3.0.1 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G+
+ Lite 2008q3-72) ) #255 Thu Dec 1 13:57:30 CST 2011
S3C24XX Clocks, Copyright 2004 Simtec Electronics
camera: no parent clock specified
S3C64XX: PLL settings, A=532000000, M=532000000, E=24000000
S3C64XX: HCLK2=266000000, HCLK=133000000, PCLK=66500000
mout_apll: source is fout_apll (1), rate is 532000000
mout_epll: source is epll (1), rate is 24000000
mout_mpll: source is mpll (1), rate is 532000000
mmc_bus: source is mout_epll (0), rate is 24000000
usb-bus-host: source is clk_48m (0), rate is 48000000
uclk1: source is dout_mpll (1), rate is 66500000
spi-bus: source is mout_epll (0), rate is 24000000
audio-bus: source is mout_epll (0), rate is 24000000
irda-bus: source is mout_epll (0), rate is 24000000
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,11520
0
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total
Memory: 255256k/255256k available, 6888k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff600000 - 0xffe00000 ( 8 MB)
vmalloc : 0xd0800000 - 0xf4000000 ( 568 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0029000 ( 132 kB)
.text : 0xc0029000 - 0xc03e2048 (3813 kB)
.data : 0xc03e4000 - 0xc040d028 ( 165 kB)
.bss : 0xc040d04c - 0xc0478690 ( 430 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:246 nr_irqs:246 246
VIC @f4000000: id 0x00041192, vendor 0x41
VIC @f4010000: id 0x00041192, vendor 0x41
Console: colour dummy device 80x30
console [ttySAC0] enabled
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
pid_max: default: 32768 minimum: 301
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with v6 PMU driver, 3 counters available
devtmpfs: initialized
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
s3c64xx_dma_init: Registering DMA channels
PL080: IRQ 73, at d0804000, channels 0..8
PL080: IRQ 74, at d0806000, channels 8..16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
audit: initializing netlink socket (disabled)
type=2000 audit(0.170:1): initialized
msgmni has been set to 498
alg: No test for stdrng (krng)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
LCD TYPE :: LTE480WV will be initialized
Console: switching to colour frame buffer device 60x34
fb0: s3cfb frame buffer device
fb1: s3cfb frame buffer device
fb2: s3cfb frame buffer device
fb3: s3cfb frame buffer device
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System"
s3c-hsotg s3c-hsotg: regs d0820000, irq 90
s3c-hsotg s3c-hsotg: s3c_hsotg_corereset: reset failed, GRSTCTL=00000000
s3c-hsotg s3c-hsotg: GRXFSIZ=0x00001800, GNPTXFSIZ=0x18001800
s3c-hsotg s3c-hsotg: shared fifos
s3c-hsotg s3c-hsotg: DCFG=0x00200000, DCTL=0x00000002, DIEPMSK=0000000f
s3c-hsotg s3c-hsotg: GAHBCFG=0x00000000, 0x44=0x00000000
s3c-hsotg s3c-hsotg: GRXFSIZ=0x00000800, GNPTXFSIZ=0x04000800
s3c-hsotg s3c-hsotg: DPTx[1] FSize=768, StAddr=0x00000f00
s3c-hsotg s3c-hsotg: DPTx[2] FSize=768, StAddr=0x00001200
s3c-hsotg s3c-hsotg: DPTx[3] FSize=768, StAddr=0x00001500
s3c-hsotg s3c-hsotg: DPTx[4] FSize=768, StAddr=0x00001800
s3c-hsotg s3c-hsotg: DPTx[5] FSize=768, StAddr=0x00001b00
s3c-hsotg s3c-hsotg: DPTx[6] FSize=768, StAddr=0x00001e00
s3c-hsotg s3c-hsotg: DPTx[7] FSize=768, StAddr=0x00002100
s3c-hsotg s3c-hsotg: DPTx[8] FSize=768, StAddr=0x00002400
s3c-hsotg s3c-hsotg: DPTx[9] FSize=768, StAddr=0x00002700
s3c-hsotg s3c-hsotg: DPTx[10] FSize=768, StAddr=0x00002a00
s3c-hsotg s3c-hsotg: DPTx[11] FSize=768, StAddr=0x00002d00
s3c-hsotg s3c-hsotg: DPTx[12] FSize=768, StAddr=0x00003000
s3c-hsotg s3c-hsotg: DPTx[13] FSize=768, StAddr=0x00003300
s3c-hsotg s3c-hsotg: DPTx[14] FSize=768, StAddr=0x00003600
s3c-hsotg s3c-hsotg: DPTx[15] FSize=768, StAddr=0x00003900
s3c-hsotg s3c-hsotg: ep0-in: EPCTL=0x00008000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep0-out: EPCTL=0x00008000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep1-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep1-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep2-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep2-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep3-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep3-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep4-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep4-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep5-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep5-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep6-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep6-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep7-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep7-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep8-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep8-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep9-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep9-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep10-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep10-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep11-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep11-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep12-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep12-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep13-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep13-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep14-in: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: ep14-out: EPCTL=0x00000000, SIZ=0x00000000, DMA=0x00000000
s3c-hsotg s3c-hsotg: DVBUSDIS=0x000017d7, DVBUSPULSE=000005b8
android init
android_probe pdata: c03ebbd4
android_bind
android_usb gadget: android_usb ready
s3c-hsotg s3c-hsotg: EP0: DIEPCTL0=0x00008000, DOEPCTL0=0x00008000
s3c-hsotg s3c-hsotg: DCTL=0x00000002
s3c-hsotg s3c-hsotg: EP0: DIEPCTL0=0x00008000, DOEPCTL0=0x80008000
s3c-hsotg s3c-hsotg: S3C_GINTSTS_USBSusp
s3c-hsotg s3c-hsotg: bound driver android_usb
f_adb init
android_register_function adb
f_mass_storage init
android_register_function usb_mass_storage
android_usb gadget: invalid number of LUNs: 0
adb_bind_config
mousedev: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /devices/virtual/input/input1
s3c-rtc s3c64xx-rtc: rtc disabled, re-enabling
s3c-rtc s3c64xx-rtc: rtc core: registered s3c as rtc0
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
s3c-sdhci s3c-sdhci.0: clock source 0: hsmmc (133000000 Hz)
s3c-sdhci s3c-sdhci.0: clock source 1: hsmmc (133000000 Hz)
s3c-sdhci s3c-sdhci.0: clock source 2: mmc_bus (24000000 Hz)
mmc0: SDHCI controller on samsung-hsmmc [s3c-sdhci.0] using ADMA
s3c-sdhci s3c-sdhci.1: clock source 0: hsmmc (133000000 Hz)
s3c-sdhci s3c-sdhci.1: clock source 1: hsmmc (133000000 Hz)
s3c-hsotg s3c-hsotg: s3c_hsotg_irq: USBRst
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
mmc1: SDHCI controller on samsung-hsmmc [s3c-sdhci.1] using ADMA
NET: Registered protocol family 17
s3c-rtc s3c64xx-rtc: setting system clock to 2000-11-04 09:48:34 UTC (973331314)
VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
devtmpfs: mounted
Freeing init memory: 132K
s3c-hsotg s3c-hsotg: new device is high-speed
mmc0: new SDHC card at address 1234
mmcblk0: mmc0:1234 SA04G 3.65 GiB
mmcblk0: p1
s3c-hsotg s3c-hsotg: new address 1
FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, fi
lesystem will be case sensitive!
/etc/rc.d/init.d/netd: line 16: /usr/sbin/inetd: not found
mkdir: cannot create directory '/mnt/disk': File exists
yaffs: dev is 32505859 name is "mtdblock3" rw
yaffs: passed flags ""
ifconfig: socket: Address family not supported by protocol
Try to bring eth0 interface up......ifconfig: socket: Address family not support
ed by protocol
route: socket: Address family not supported by protocol
Done
Starting Qtopia2, please waiting...
Please press Enter to activate this console. touch...
windows下出现无法识别的USB设备
然后在回车
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: c0282
1fc
[<c002fca8>] (unwind_backtrace+0x0/0xfc) from [<c028113c>] (dump_stack+0x18/0x1c
[<c028113c>] (dump_stack+0x18/0x1c) from [<c02811a0>] (panic+0x60/0x1ac)
[<c02811a0>] (panic+0x60/0x1ac) from [<c004591c>] (__stack_chk_fail+0x18/0x1c)
[<c004591c>] (__stack_chk_fail+0x18/0x1c) from [<c02821fc>] (schedule_timeout+0x
240/0x2a8)
[<c02821fc>] (schedule_timeout+0x240/0x2a8) from [<c0256130>] (__skb_recv_datagr
am+0x254/0x264)
[<c0256130>] (__skb_recv_datagram+0x254/0x264) from [<c0256168>] (skb_recv_datag
ram+0x28/0x30)
[<c0256168>] (skb_recv_datagram+0x28/0x30) from [<c02767e8>] (unix_dgram_recvmsg
+0xa8/0x3e0)
[<c02767e8>] (unix_dgram_recvmsg+0xa8/0x3e0) from [<c0249934>] (sock_aio_read+0x
144/0x164)
[<c0249934>] (sock_aio_read+0x144/0x164) from [<c00df26c>] (do_sync_read+0xb0/0x
f4)
[<c00df26c>] (do_sync_read+0xb0/0xf4) from [<c00dffac>] (vfs_read+0x148/0x150)
[<c00dffac>] (vfs_read+0x148/0x150) from [<c00e0090>] (sys_read+0x44/0x74)
[<c00e0090>] (sys_read+0x44/0x74) from [<c0029b40>] (ret_fast_syscall+0x0/0x30)
内核崩溃 |
