好久没看DesignIdea了.....
虽说没少仿真过分立元件搭建的运放,不过这个电路还是让我想仿真下,看看性能如何,结果.....
原文地址:http://www.edn.com/article/520186-Build_an_op_amp_with_three_discrete_transistors.php
Build an op amp with three discrete transistors
This simple ac-coupled design inverts, runs off a single supply, and is self-biasing.
Lyle Russell Williams, St Charles, MO; Edited by Paul Rako and Fran Granville -- EDN, December 1, 2011
You can use three discrete transistors to build an operational amplifier with an open-loop gain greater than 1 million (Figure 1). You bias the output at approximately one-half the supply voltage using the combined voltage drops across zener diode D1, the emitter-base voltage of input transistor Q1, and the 1V drop across 1-MΩ feedback resistor R2.
(原文件名:1.png)
Build an op amp with three discrete transistors figure 1Resistor R3 and capacitor C1 form a compensation network that prevents the circuit from oscillating. The values in the figure still provide a good square-wave response. The ratio of R2 to R1 determines the inverting gain, which is −10 in this example.
You can configure this op amp as an active filter or as an oscillator. It drives a load of 1 kΩ. The square-wave response is good at 10 kHz, and the output reduces by 3 dB at 50 kHz. Set the 50-Hz low-frequency response with the values of the input and the output capacitors. You can raise the high-frequency response by using faster transistors and doing careful layout.
(原文件名:2.png)
交流分析:
(原文件名:3.png)
以下为谐波失真分析的设置及曲线:
(原文件名:4.png)
(原文件名:5.png)
(原文件名:6.png) |
